BAD WB Offline
#1 Posted : Thursday, 13 September 2007 7:16:54 PM(UTC)
BAD WB
Gday all. Im thinking about changing my gear box in my ute to a Turbo 400. Running a 308, Currently i have a Supra 5 speed, and running a 10 bolt salsbury with 3.08 lsd. just wondering how bigger task this is going to be. any ideas and tips would be great. Cheers.
#2 Posted : Thursday, 13 September 2007 10:16:56 PM(UTC)
You are a member of these groups:: Moderator, Registered, Veteran
It's an easy conversion IF you already have a TH (otherwise known as turbo) pattern 308. Assuming you already have the right block and the factory hole is in the floor this is what you need to do:
Buy a box (including vacuum line), flex plate/bolts, cr
#3 Posted : Thursday, 13 September 2007 10:16:56 PM(UTC)
Its an easy conversion IF you already have a TH (otherwise known as turbo) pattern 308. Assuming you already have the right block and the factory hole is in the floor this is what you need to do:
Buy a box (including vacuum line), flex plate/bolts, cro
