zakrasm Offline
#1 Posted : Monday, 17 September 2007 6:57:25 AM(UTC)
zakrasm
Gday everyone. I have a HJ ute that's been fitted with the complete front suspension from a HX Statesman. Upper and lower arms, drag link tie roads, stub axles etc. It also has power steering. The thing is terrible to drive in a straight line, it darts all over the place. I know the HX drag link is different to the HJ so should I change this or anything else before I send it in for a wheel alignment? Cheers, Mark
Duzty Offline
#2 Posted : Tuesday, 18 September 2007 2:23:05 AM(UTC)
Duzty
maybe get a steering/suspension place to check it out if you dont know what the problem is.
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, f
zakrasm Offline
#3 Posted : Thursday, 20 September 2007 5:39:46 AM(UTC)
zakrasm
I know the car needs a wheel alignment. All the bushes, ball joints etc. are almost new. I just need to know if I can use the later style drag link on a HJ or if I should go out and buy a HJ one before I get the wheel alignment done. Also does anyone have
74HJLS Offline
#4 Posted : Tuesday, 25 September 2007 6:58:32 PM(UTC)
74HJLS
As far as I know HJ and HX were the same, nothing changed until the RTS in the HZ.
The bloke you go to to get your front end aligned will have the settings and they should be both the same. It sounds like your castor is out.
Pete.
Old Holden
Edited by user Tuesday, 25 September 2007 6:59:15 PM(UTC)  | Reason: Not specified
Pete.
