Handgunner Offline
#1 Posted : Friday, 21 September 2007 11:33:14 PM(UTC)
Handgunner
Hi everyone...first up , i have read thru lots of posts and still dont quite get it...lol..... my issue is this... i have put a 202 with electronic dizzy into my ht( ex 186 points)and now, as i beleive , i need to give the coil a 12 volt supply for ignition..( it wont start atm .. it has gas installed too.. i need to know what kind of a relay should i buy ? and how exactly do i hook it up? I have a yellow ignition wire, a brown wire to the coil neg for the gas.. it appears that my starter motor switching wire is not working either? but when i use a screwdriver to hot wire it, or run 12 volts from the battery, it will crank over..
is this all related to the 12 volt coil supply?
I know its not too technical for some, but i am getting a little lost....and does a relay have to be wired wiuth a + and - to power it , and then an ignition wire in and then back out to the coil + ?
I have an old light relay from another HT , but it only has 2 brass connector tabs..can i use this?
Thanks for the enlightenment :)
Anthony
Bang Bang
Bang Bang
ozjason Offline
#2 Posted : Friday, 21 September 2007 11:52:40 PM(UTC)
ozjason
Hi,
My honest opinion, is to forget your relay, and get your engine running again with temporary wires, until you have found the problem.
Your cranking issue wont be to do with the coil - a starter motor will turn the motor over until the battery fl
ozjason Offline
#3 Posted : Friday, 21 September 2007 11:52:40 PM(UTC)
ozjason
Hi,
Your cranking issue won't be to do with the coil - a starter motor will turn the motor over until the battery f
#4 Posted : Saturday, 22 September 2007 1:46:33 AM(UTC)
ozjason what do you mean by orientation as the points system and it wont start ? i have all the gear to do the change and can get 12volts from ignition by bypassing the balest wire but not sure what position to put the dizzy in to make sure it fires chee
ozjason Offline
#5 Posted : Saturday, 22 September 2007 4:44:28 AM(UTC)
ozjason
Hey John,
I actually cheated - I took my points dizzy out (and took note of which way around it was pointing when I took it out), and didnt let the engine move. So when I put my electronic dizzy in, I just had to account for the slight twist it makes
ozjason Offline
#6 Posted : Saturday, 22 September 2007 4:44:28 AM(UTC)
ozjason
Hey John,
I actually cheated - I took my points dizzy out (and took note of which way around it was pointing when I took it out), and didn't let the engine move. So when I put my electronic dizzy in, I just had to account for the slight twist it makes
christoss Offline
#7 Posted : Saturday, 22 September 2007 10:34:02 AM(UTC)
christoss
Gday all,
set your motor to top dead centre No1 compression stroke( if in doubt remove #1 plug and stick your finger in the hole and turn the engine over by hand when
christoss Offline
#8 Posted : Saturday, 22 September 2007 10:34:02 AM(UTC)
christoss
G'day all,
coley13 Offline
#9 Posted : Saturday, 22 September 2007 4:42:03 PM(UTC)
coley13
first off all go back to the basics to see where the problem is.
pull a plug lead and check for spark. if NO spark jump a wire directly from battery to the positive side of the coil and see if it starts. if it starts it was wired up wrong.
if it HAS
vintageholden Offline
#10 Posted : Saturday, 22 September 2007 11:55:19 PM(UTC)
vintageholden
i have the same problem
what do i do with the pink wire from the dizzy
car runs but not as good since i fitted the electric dizzy
Edited by user Saturday, 22 September 2007 11:56:18 PM(UTC)  | Reason: Not specified
#11 Posted : Sunday, 23 September 2007 2:21:22 AM(UTC)
The reason vintageholden that your car runs worse is that balisresistor wire that was talked about. With the old coil the car only needs about 8volts while running but a electronic dizzy needs 12 all the time. Hook the dizzy to 12volts and see if it impro
#12 Posted : Sunday, 23 September 2007 2:26:14 AM(UTC)
The pink wire is the "gay wire" - best off not connecting it to anything.
ozjason Offline
#13 Posted : Sunday, 23 September 2007 3:34:14 AM(UTC)
ozjason
Another possible reason for an engine not running as well after installing an electronic dizzy, is that the spark gap on your plugs may be too small for electronic ignition.
A points system needs about 0.9mm from memory, but electronic ignition may wor
#14 Posted : Monday, 24 September 2007 1:48:48 AM(UTC)
vintageholden
thanks i,ll give it a go
#15 Posted : Tuesday, 25 September 2007 5:12:15 AM(UTC)
Ok, i have had a go at installing the positive wire to the coils straight from the battery and it now cranks over....BUT, it wont fire up properly, i sprayed aerostart down the manifold , it fires a little bit and then wont run on... maybee the gas is c
coley13 Offline
#16 Posted : Tuesday, 25 September 2007 7:13:45 PM(UTC)
coley13
id be checking the wiring for the lpg. make sure the valves are opening for gas supply. there should be a safety cut out switch that runs ignition power. another wire should be run from the negative side of the coil to the switch. once the the switch sens
coley13 Offline
#17 Posted : Tuesday, 25 September 2007 7:13:45 PM(UTC)
coley13
i'd be checking the wiring for the lpg. make sure the valves are opening for gas supply. there should be a safety cut out switch that runs ignition power. another wire should be run from the negative side of the coil to the switch. once the the switch sen
vulcan2509 Offline
#18 Posted : Tuesday, 9 October 2007 8:31:04 PM(UTC)
vulcan2509
GO to oldholden.com and look for Reapers tips on this topic its quite easy to follow.
"With A Name Like Brock What Else Would I Drive"
80737k Offline
#19 Posted : Wednesday, 10 October 2007 2:04:47 AM(UTC)
80737k
Fossil fuels are YUMMY !
Guest (7)
This page was generated in 0.094 seconds.
