#1 Posted : Sunday, 23 September 2007 1:46:22 AM(UTC)
Hi does anyone know if HK bucket seats will bolt straight into an EH or a HR or do they need different brackets?
#2 Posted : Sunday, 23 September 2007 3:18:06 AM(UTC)
Hi Holden Premier.
Yes, EJ to HR buckets will fit the HK/T/G floorpan. All you need to do is drill the 4 holes for the inner rails in the correct location & everything will work OK.
#3 Posted : Sunday, 23 September 2007 3:31:38 AM(UTC)
Thanks Dr T
#4 Posted : Sunday, 23 September 2007 4:23:46 AM(UTC)
If the car already had buckets are the holes already in the right spot? Or you have to drill more?
vintageholden Offline
#5 Posted : Sunday, 23 September 2007 5:11:08 AM(UTC)
vintageholden
drill more
#6 Posted : Monday, 24 September 2007 2:44:18 AM(UTC)
Hi Holden Premier.
If your HK already had buckets, then the EJ/HR seats will bolt straight ih.
