Hi does anyone know if HK bucket seats will bolt straight into an EH or a HR or do they need different brackets?
Hi Holden Premier.
Yes, EJ to HR buckets will fit the HK/T/G floorpan. All you need to do is drill the 4 holes for the inner rails in the correct location & everything will work OK.
Dr Terry |
If the car already had buckets are the holes already in the right spot? Or you have to drill more?
Hi Holden Premier.
If your HK already had buckets, then the EJ/HR seats will bolt straight ih.
Dr Terry |
