#1 Posted : Wednesday, 26 September 2007 1:36:36 AM(UTC)
can you buy kline valve guides and fit them your self or is it a job for an expert ? cheers
#2 Posted : Thursday, 27 September 2007 5:10:15 PM(UTC)
Yes you can. But it will cost you around $800.00 for the tooling to fit them correctly.
Shane.
ozchevy Offline
#3 Posted : Friday, 28 September 2007 8:09:05 AM(UTC)
ozchevy
Hi guys,
Fitting valve guides is not an easy thing to do if you are unsure of the precedure.
Firstly the bore that the guide is to be inserted into, needs to be a 6-8 thou interference fit.
The best way to fit them without any damage by cracking to
This page was generated in 0.149 seconds.
