HarryO Offline
#1 Posted : Wednesday, 26 September 2007 7:27:00 AM(UTC)
HarryO
Background: 186, 4 speed Toyo box, hydraulic clutch using std firewall master.
Issue: Very high pitched squeal/whine.
When?: Cold - up to 5 minutes - intermittent.
Short term cure: A mere tap of the clutch pedal instantly stops it.
Eliminated (maybe?): No fluid loss, new master.
Thoughts: Thought it may be carb leak, but a slight touch (slight!) to the clutch pedal stops it. Warmed up (180+), not a sound! Zero fluid loss from the master.
Ideas?
Cheers, Paul.
crowe Offline
#2 Posted : Wednesday, 26 September 2007 8:22:34 AM(UTC)
crowe
Sounds like your thrust bearing a bit dry.
HarryO Offline
#3 Posted : Thursday, 27 September 2007 7:21:56 AM(UTC)
HarryO
Thanks for the info. Is that a low oil issue or grease issue? Looking to re-pull the engine/box out to replace a gasket in any event. Cheers, Paul.
Edited by user Thursday, 27 September 2007 7:24:58 AM(UTC)  | Reason: Not specified
keithholden Offline
#4 Posted : Thursday, 27 September 2007 5:06:57 PM(UTC)
keithholden
If the thrust bearing is adjusted to far in it will touch the fingers of the pressure plate causing it to spin all the time.
This will as with any bearing spining all the time wear it out over time.
Take the cover off the bottom of the gearbox if the
adam PERTH Offline
#5 Posted : Saturday, 29 September 2007 8:06:24 AM(UTC)
adam PERTH
Given you have an aftermarket belhousing, there is a chance you are not running your inspection cover??
If you are / aren't, whatever, but get some gear oil 80W /90 in an oil can and pump it onto the bearing to while turning it by hand.
Heat the oil +
adam PERTH Offline
#6 Posted : Saturday, 29 September 2007 8:06:24 AM(UTC)
adam PERTH
If you are / arent, whatever, but get some gear oil 80W /90 in an oil can and pump it onto the bearing to while turning it by hand.
Heat the oil +
