CATFORD Offline
#1 Posted : Thursday, 27 September 2007 6:40:24 AM(UTC)
CATFORD
Hi all,
I have a 1976 F100 with a 302 Clevo....the othe day I drove it abot 60 k's and on returning I turned it off and went to restart it soon after....but it cranked slowly and eventually stopped.
The next day I jump started it...which worked fine....after it started fine I turned it off and charged the battery...I noticed the water level in the battery to be low so I topped them up.
After recharging it I started it up and checked the voltage and it read 17-18.5 Volts at idle....I then replaced the volatge regulator and still the same....I also have re-wired and teminated all wiring between Alternator, Voltage Reg and battery.
But still the same starts of at 13.8 volts....but climbs all the way to 16.8 volts....a little better but still not right.
Any ideas...I was thinking alternator but wouldnt that put out a low voltage if it has failed or was on its way out.
The numbers on the alternator are:- ( For info )
912006C816
U-K1 14V 40A 22
76DA-10300-A
Motorcraft
Anyway I hope someone can help me out....if it is the alternator what do they cost to replace!!!
Cheers Matt!
#2 Posted : Friday, 28 September 2007 2:34:26 AM(UTC)
I thought you would have knows better than to buy another ford mate, they are disgusting!
Dmax Offline
#3 Posted : Friday, 28 September 2007 7:15:13 PM(UTC)
Dmax
Sounds like a faulty regulator, maybe?
648hp Tunnel Rammed 351, It does not get any better
#4 Posted : Sunday, 7 October 2007 2:02:26 AM(UTC)
Sounds to me like CATFORD needs to clear the cob webs from his wallet and buy a multimeter that costs more than $9.99 from Supercheap? Com\on CAT, inform us all- what was the problem?
(still ****'n through the eye of a needle?)
sparkzy Offline
#5 Posted : Sunday, 7 October 2007 8:07:34 AM(UTC)
sparkzy
I to had same on my xf mate I replaced Altenator and problem solved.
Also I was told to be carful as your battery can explode with the water running dry and you should be able to smell the acid cooking to.
[IMG]http://i195.photobucket.com/albums/z
Edited by user Sunday, 7 October 2007 8:16:23 AM(UTC)  | Reason: Not specified
FORD MUSCLE
This page was generated in 0.150 seconds.
