briane Offline
#1 Posted : Friday, 28 September 2007 3:45:58 AM(UTC)
briane
G`day all. Have a slight prob with my red 6 in an LC Torry. The engine is a .020 over 202 but otherwise stock, running back thru a stock traumatic box. Prob is that when I back off to go round a sharpish corner for instance, when I put my foot back into it ( even slightly ) it has an almighty flat spot and quite often stalls. If I pull the choke out an inch or so, it seems to alleviate the prob. I have been thru the electrics and timing side of things and all seems ok ( replaced it all !!) so I`m guessing Fuel/ carby prob. Car was running ok and this prob came out of the blue. Thanks in advance for any advice..Cheers..Brian
christoss Offline
#2 Posted : Friday, 28 September 2007 6:41:34 AM(UTC)
christoss
check for vacuum leaks very common around intake manifold gasket. Check to make sure bolts are tight.Use a can of carby cleaner to spray around any potential vacuum leaks and listen for a change in engine revs which would indicate a leak.Or may be carby p
vintageholden Offline
#3 Posted : Friday, 28 September 2007 11:03:50 AM(UTC)
vintageholden
i had the same problem
rebuilt the carby now its fine
get a kit from supercheep etc
briane Offline
#4 Posted : Saturday, 29 September 2007 2:53:08 AM(UTC)
briane
Thanks guys, will give it a try..Cheers...Brian
