#1 Posted : Saturday, 29 September 2007 8:36:43 AM(UTC)
hi there just looking for some advise i have mild 383 chev with mechanical fan and stock fuel pump .i am thinking of changing to electric fan and holley blue fuel pump to gain some power .is it worth it?any suggestions would be appreciated
crowe Offline
#2 Posted : Saturday, 29 September 2007 11:39:17 PM(UTC)
crowe
This is a good topic- The problem with an electric fan is- yes they do save power, however they normally switch in once the motor gets hot/ warm. If you put a clutch hub fan on then you do save some power but its self regulating as the air passing over it
hz dude Offline
#3 Posted : Sunday, 30 September 2007 1:41:21 AM(UTC)
hz dude
what might be the net gain of HP for doing such an expensive conversion
what money to horsepower ratio for the conversion
just keen to know
its beer oclock
hz dude Offline
#4 Posted : Sunday, 30 September 2007 1:41:21 AM(UTC)
hz dude
just keen to know
it's beer o'clock
#5 Posted : Sunday, 30 September 2007 6:39:34 AM(UTC)
i already have the holley blue pump and my mate has a spare regulater .a new au [i think] fan with shroud costs about 250 so if i can get a small gain i reckon its worth it.any idea what sort of gain i would get ?
#6 Posted : Sunday, 30 September 2007 10:25:12 AM(UTC)
surely someone knows this?
#7 Posted : Sunday, 30 September 2007 7:02:26 PM(UTC)
I dont think youll get any hp increase out of a Holley blue. ALl itll do is stop fuel starvation at maximum rpm. And gain from the loss of the mechanical accessory will probably be lost in additional alternator drain. The electric fans will gain you hp an
#8 Posted : Sunday, 30 September 2007 7:02:26 PM(UTC)
I don't think you'll get any hp increase out of a Holley blue. ALl it'll do is stop fuel starvation at maximum rpm. And gain from the loss of the mechanical accessory will probably be lost in additional alternator drain. The electric fans will gain you hp
#9 Posted : Sunday, 30 September 2007 7:43:24 PM(UTC)
its a hk brougham with a standard chev radiater thats been recored recently i think it has 170 thermostat .it has standard fan and with this combination it does;nt get hot even in traffic .
jabba Offline
#10 Posted : Monday, 1 October 2007 3:30:05 PM(UTC)
jabba
An electric fuel pump is only really worth it if you always run very hard. Mechanicals are actually very effective and efficient. If the engine is running harder, the pump is sending more fuel, so is keeping up. With an electric, there isnt the direct
jabba Offline
#11 Posted : Monday, 1 October 2007 3:30:05 PM(UTC)
jabba
An electric fuel pump is only really worth it if you always run very hard. Mechanicals are actually very effective and efficient. If the engine is running harder, the pump is sending more fuel, so is keeping up. With an electric, there isn't the direct
adam PERTH Offline
#12 Posted : Tuesday, 2 October 2007 7:54:18 AM(UTC)
adam PERTH
Jabbba,
I know what your saying.
I never had any dramas with overheating chevs in Tasmania - simular to NZ.
But, when you go north on the big island, it really tests things out
A1 Bogan.
