Fred Offline
#1 Posted : Sunday, 30 September 2007 10:05:11 AM(UTC)
Fred
Does anyone know where I would be able to purchase blank disc brake rotors for a VP Commodore, Id like to have them drilled to suit the Ford stud pattern. Our rod is using HT Holden sub frame with VP Commodore brakes, Holden 253 V8 and a M21 4 speed with a EB Ford differential.
This is why I need to have the blank rotors drilled so to match the rear end and no we can't use a Holden rear end as the Ford end is already mounted, we tried a Commodore rear end but the Ford has a much better disc brake setup and a breeze to have connected to the handbrake.
God is Dog spelt backwards.
#2 Posted : Sunday, 30 September 2007 6:54:49 PM(UTC)
Try DBA or RDA. They may be able to do them for you for a cost? Make sure the base circle of the hub is the same as the rear first.
If we all had the same (good) taste, who would buy all the Ford
#3 Posted : Tuesday, 2 October 2007 10:40:32 PM(UTC)
Edited by user Tuesday, 2 October 2007 11:14:14 PM(UTC)  | Reason: Not specified
Fred Offline
#4 Posted : Wednesday, 3 October 2007 9:58:46 AM(UTC)
Fred
Bryon, Explain to me why the circle of the front discs need to be that of the rear disc's please. DBR don't have blank VP discs, Ive already phoned and asked, can't you get some rotors that the centers bolt in. Fred
Fred Offline
#5 Posted : Wednesday, 3 October 2007 9:58:46 AM(UTC)
Fred
Bryon, Explain to me why the circle of the front discs need to be that of the rear discs please. DBR dont have blank VP discs, Ive already phoned and asked, cant you get some rotors that the centers bolt in. Fred
Fred Offline
#6 Posted : Thursday, 4 October 2007 7:43:07 AM(UTC)
Fred
Well guys I sent an email to Hopper Stopper and received this reply:
There are two sizes available for blank VP rotors, 270 by 22 or 287 by 22
Ill head over to the shed tomorrow and measure the EB rotors and the standard EB interceptor rims.
Thanks fo
Fred Offline
#7 Posted : Thursday, 4 October 2007 7:43:07 AM(UTC)
Fred
I'll head over to the shed tomorrow and measure the EB rotors and the standard EB interceptor rims.
Thanks f
#8 Posted : Thursday, 4 October 2007 8:00:42 AM(UTC)
Yep the smaller ones are the series 1 V6 and the larger ones are the series 2 V6 and all V8.
It shi ts me to tears when the media & state politicians
#9 Posted : Thursday, 4 October 2007 4:12:15 PM(UTC)
The centre of the hub is where all the weight is meant to be taken. Wheel studs are only supposed to hold the wheel on. If the Commodore hub is smaller than the Ford, the wheels will go on but all the weight will be on the studs. If the Commodore hub is b
#10 Posted : Sunday, 7 October 2007 6:13:21 AM(UTC)
Here is a bit of lateral thought. Why not get your EB rear axles & rotors re drilled to Commodore pattern? You might even be lucky enough to get away with just drilling your axles & using Commodore rotors with the EB brake setup (murphys law says you woul
Edited by user Sunday, 7 October 2007 6:36:44 AM(UTC)  | Reason: Not specified
#11 Posted : Sunday, 7 October 2007 6:13:21 AM(UTC)
Here is a bit of lateral thought. Why not get your EB rear axles & rotors re drilled to Commodore pattern? You might even be lucky enough to get away with just drilling your axles & using Commodore rotors with the EB brake setup (murphy's law says you wou
#12 Posted : Sunday, 7 October 2007 6:34:56 AM(UTC)
Ok I've just been out a measuring. It's easy when your daily driver is an EB and your Wifes daily driver is a VP & you just happen to have spare rear ends for both in your back yard (much to her chagrin I might add).
There is no way the Commodore re
#13 Posted : Sunday, 7 October 2007 6:34:56 AM(UTC)
Ok Ive just been out a measuring. Its easy when your daily driver is an EB and your Wifes daily driver is a VP & you just happen to have spare rear ends for both in your back yard (much to her chagrin I might add).
There is no way the Commodore rear
Guest (6)
