hainzy Offline
#1 Posted : Monday, 1 October 2007 7:42:58 AM(UTC)
hainzy
HI guys.
Can someone tell me if a 4 cylinder opel 4 speed LX sunbird is basically the same as a 253 4 speed LX? I mean in terms of the basic body, chassis all that kind of stuff. Basically for reshelling of a rusty car? Cheers.
JBM Offline
#2 Posted : Monday, 1 October 2007 8:21:14 AM(UTC)
JBM
I would transfer all the mechanicals including the front suspension from the six to the 4 body, I htink the front cross member is different and the front brakes were drums.
At least youll have an unstressed body to work with.
James
hainzy Offline
#3 Posted : Monday, 1 October 2007 9:03:00 AM(UTC)
hainzy
thanx JBM.
Drum brakes - Good point. By front crossmember do you mean gearbox crossmember? I would do that i guess and yep all the front end and diff too. The 253 is i think 76 and the sunbird is 77 so i think they should both be RTS. Apart from that eve
JBM Offline
#4 Posted : Monday, 1 October 2007 4:24:04 PM(UTC)
JBM
Front cross member goes under the engine.
James
adam PERTH Offline
#5 Posted : Tuesday, 2 October 2007 7:01:22 AM(UTC)
adam PERTH
make sure you change the original 3.90 diff centre to something,.... anything else but 3.90.
A1 Bogan.
#6 Posted : Tuesday, 2 October 2007 7:23:36 AM(UTC)
Depending upon the gearbox some 4cyl examples had the box mounted further forward and hence the gearstick is in the wrong spot. I think it was a UC with Starfire and MC6 where I found this out. As JBM says the Opel powered LX has a different front crossme
