el_jay_72 Offline
#1 Posted : Monday, 1 October 2007 8:11:29 AM(UTC)
el_jay_72
Hi I was thinking about purchasing a set of 18" rims to fit on to my lj torana. What i want to know is will they fit and if not how much work is needed to fit them under the guards. Also if thats too hard what would be the difficulty level in fitting 17s and how much work is needed. If you can help me out it would be greatly appreciated and if not at least u read all the way to the end...
Jason Smith
Still Torrie Mad
Torrie Mad
peter_flane Offline
#2 Posted : Tuesday, 2 October 2007 5:42:45 AM(UTC)
peter_flane
Anything can fit if you want it to. You will have to get correct offset, low profile, and probably pump the guards based on the narrowest tyre/ rim combo you can buy.
I will also add personal option, and it is your choice to ignore it, but I would not
adam PERTH Offline
#3 Posted : Tuesday, 2 October 2007 7:46:35 AM(UTC)
adam PERTH
17"?
too much bling for me.
whats wrong with the 13 x 7" chromie with original hub cap?
A1 Bogan.
vintageholden Offline
#4 Posted : Tuesday, 2 October 2007 12:23:14 PM(UTC)
vintageholden
all 13" should go in the bin there to small and look crap
(JUST MY OPPINION)
#5 Posted : Tuesday, 2 October 2007 4:09:56 PM(UTC)
go for a tyre rim combo that will be the same height as standard, try a 14 or 15 with low profile, keeping the same height will give less drama all round
This page was generated in 0.120 seconds.
