#1 Posted : Wednesday, 3 October 2007 1:49:12 AM(UTC)
are all 202 water pumps the same ? i heard the 3.3 blue pump is a better pump cheers
#2 Posted : Wednesday, 3 October 2007 2:25:23 AM(UTC)
Was thanked: 219 time(s) in 199 post(s)
Hi Guys.
I've cut & pasted this from another forum, where I answered a similar question a while ago.
Many parts catalogues don’t list these pumps properly.
There are actually 4 different water pumps for the Holden Red/Blue/Black 6.
1. EH to
#3 Posted : Wednesday, 3 October 2007 2:25:23 AM(UTC)
Hi Guys.
Ive cut & pasted this from another forum, where I answered a similar question a while ago.
1. EH to H
#4 Posted : Wednesday, 3 October 2007 2:42:01 AM(UTC)
thanks dr terry so the jumbo pump w815 would be best for cooling right ? cheers ps if thats not a dumb statement
#5 Posted : Wednesday, 3 October 2007 2:48:19 AM(UTC)
Hi john.
AFAIK they all pump the same volume in factory form. I don't think a Jumbo pump would pump any more water than an EH/HK pump, but it does have a bigger (stronger ??) bearing.
It does appear however, that some aftermarket pumps with pressed
#6 Posted : Wednesday, 3 October 2007 2:48:19 AM(UTC)
Hi john.
AFAIK they all pump the same volume in factory form. I dont think a Jumbo pump would pump any more water than an EH/HK pump, but it does have a bigger (stronger ??) bearing.
It does appear however, that some aftermarket pumps with pressed s
adam PERTH Offline
#7 Posted : Wednesday, 3 October 2007 9:33:53 AM(UTC)
adam PERTH
"faster flow DOES NOT = better cooling."
SOURCE: Smokey Yuknik Chev power secrets.
slower is better to achieve the latent heat transfer.
hi reving motors actually gear down the water pump pulley.
A1 Bogan.
#8 Posted : Wednesday, 3 October 2007 5:45:55 PM(UTC)
adam PERTH Offline
#9 Posted : Thursday, 4 October 2007 7:45:08 AM(UTC)
adam PERTH
My point was that the STD GM stuff is "a OK"
ok up to 2 HP : 1 Cubic inch.
A1 Bogan.
#10 Posted : Thursday, 4 October 2007 4:16:39 PM(UTC)
I'd have to agree totally with Terry on the uselessness of the pressed stell impellers. My Overlander's red 308 had an aftermarket pump on it with the cheap impeller. When I changed it to a later model pump with the bigger bearing it had the cast iron bar
#11 Posted : Thursday, 4 October 2007 4:16:39 PM(UTC)
Id have to agree totally with Terry on the uselessness of the pressed stell impellers. My Overlanders red 308 had an aftermarket pump on it with the cheap impeller. When I changed it to a later model pump with the bigger bearing it had the cast iron barre
This page was generated in 0.066 seconds.
