#1 Posted : Thursday, 4 October 2007 3:37:17 AM(UTC)
Looking at buying a GTS 4 door hq. Wanting to know if its genuine, id tag reads;
Model: HQ80469
Body: 074596M
Trim: 185-30X
Paint: 567-15332
L31 M21 GV2
Long tag: 8N69TCJ373674Q
4/73
Any help will be much appreicated. The car is now VT gold.
Thanks,
Damian
#2 Posted : Thursday, 4 October 2007 4:10:25 AM(UTC)
I'd be about 100% confident it's a HQ V8 Kingswood with XV4 option (otherwise known as HQ Holden V8 GTS 4 door). The 30X trim gives it away. It's a factory 308, 4speed. You are missing a digit from the paint code - should be 1865 (not 185) - Cyan metallic
#3 Posted : Thursday, 4 October 2007 4:10:25 AM(UTC)
Id be about 100% confident its a HQ V8 Kingswood with XV4 option (otherwise known as HQ Holden V8 GTS 4 door). The 30X trim gives it away. Its a factory 308, 4speed. You are missing a digit from the paint code - should be 1865 (not 185) - Cyan metallic.
#4 Posted : Thursday, 4 October 2007 4:13:50 AM(UTC)
30x is GTS trim code, the T on the long tag says its factory 308
L31-308
M21-4spd
GV2-3:36
15332-cyan metalic (blue)
30x-black trim
melbourne assembled
looks like genuine GTS
#5 Posted : Thursday, 4 October 2007 6:47:23 AM(UTC)
is ther any chance it has stripe's
houndstooth?
it has a 5 speed and 9" now.
#6 Posted : Thursday, 4 October 2007 6:47:23 AM(UTC)
is ther any chance it has stripes
houndstooth?
#7 Posted : Thursday, 4 October 2007 4:12:03 PM(UTC)
30x is vynil only no insert, being blue it would have most likely had white patches on the hood and boot instead of black.
#8 Posted : Thursday, 4 October 2007 5:47:26 PM(UTC)
what about the black outs on sill's and slots on guards?
#9 Posted : Thursday, 4 October 2007 5:47:26 PM(UTC)
what about the black outs on sills and slots on guards?
#10 Posted : Thursday, 4 October 2007 7:20:32 PM(UTC)
yep wouldve had the standard black outs on the guards lower front nosecone, sills & rear beaver, but as for stripes I think you wouldve had a choice of black, white or deleted, from my experience there is no way to tell for sure unless you get the order i
#11 Posted : Thursday, 4 October 2007 7:20:32 PM(UTC)
yep would've had the standard black outs on the guards lower front nosecone, sills & rear beaver, but as for stripes I think you would've had a choice of black, white or deleted, from my experience there is no way to tell for sure unless you get the order
