Fred Offline
#1 Posted : Thursday, 4 October 2007 8:22:32 AM(UTC)
Fred
Can anyone tell me what is the standard sizes for the front and rear rotor on a EB Ford, sizes like 270mm or 287mm x 22mm would be ideal and if possible the distance across the top of the rotor where the studs go through.
We are building a Rod and need the Ford rotor sizes to purchase the correct rotors.
We have a HT Holden subframe welded into the chassis, the HT subframe is using HQ Holden disc brake stubs that were machined to accept a VP Commodore rotor kit. We are also using a 28 spline EB Ford rear end so to have the front and rear rims match we are going to purchase blank VP Commodore discs and have them drilled to suit the Ford stud pattern.
God is Dog spelt backwards.
#2 Posted : Friday, 5 October 2007 11:07:29 PM(UTC)
Fred This should answer most of your questions: http://www.dba.com.au/2006/catalogue_aust.asp
Centre hole diameter (E) refers to the spigot on the hub that the wheel centre bore centres on.
Oh and I just measured across the wheel mounting face on
Edited by user Friday, 5 October 2007 11:14:13 PM(UTC)  | Reason: Not specified
Fred Offline
#3 Posted : Saturday, 6 October 2007 3:01:11 AM(UTC)
Fred
Hi Jim, Well thats answered that question, problem solved. Thanks Fred.
