one tonner man Offline
#1 Posted : Thursday, 4 October 2007 9:16:57 AM(UTC)
one tonner man
I have rewired a belmont wireing loom for my gts dash but came up with a problem for the amp wire going to JW in the firewall connector.
This is a lager wire that uses a lager male/female terminal connectors I like to try and make this loom just like a proper GTS loom. Das any one may know where I can get a set of the lager male/female terminal from. I have Try rare spares with no luck
If I agreed with you we`d both be wrong.
#2 Posted : Friday, 5 October 2007 3:30:07 AM(UTC)
You will also need to wire in a dual horn on the lighting harness. You can get that from a Premier/Statesman harness.
Warren
