witcheshollow racing team Offline
#1 Posted : Monday, 8 October 2007 9:28:03 PM(UTC)
Just a quick question in relation to the cam, I have an un-used crow cam 30/70 grind sitting in the shed can this be used in the injected 202 or are they cam sensitive like the V6s? Thanks for taking the time to read and answer.
When the green flag drops the bulls@#t stops!!
"Such is life"
#2 Posted : Monday, 8 October 2007 9:55:52 PM(UTC)
The EFI cam is awful close to a 30/70 70/30 (advertised duration) if you set it up at zero degrees (ie not retarded by 6 degrees like the factory one). The Crow cam should work, but the factory one does have a slight delay in inlet closing to take into ac
