vulcan2509 Offline
#1 Posted : Tuesday, 9 October 2007 5:29:18 AM(UTC)
vulcan2509
Im currently running a 202 red in my HD.
As far as I know it is standard other than that it's been bored out 60thou.This being the case if I wanted to check compression what should my cold compession be.
"With A Name Like Brock What Else Would I Drive"
#2 Posted : Tuesday, 9 October 2007 6:01:17 AM(UTC)
Should be about 140-160psi.
adam PERTH Offline
#3 Posted : Tuesday, 9 October 2007 7:56:14 AM(UTC)
adam PERTH
compression test is usually done with a motor at running temp, not cold.
You will have lower readings with higher variance on a cold motor.
A1 Bogan.
