Im currently running a 202 red in my HD. As far as I know it is standard other than that it's been bored out 60thou.This being the case if I wanted to check compression what should my cold compession be.
"With A Name Like Brock What Else Would I Drive" |
Should be about 140-160psi.
compression test is usually done with a motor at running temp, not cold.
You will have lower readings with higher variance on a cold motor.
A1 Bogan. |
