mmazz30 Offline
#1 Posted : Tuesday, 9 October 2007 8:10:13 AM(UTC)
mmazz30
Hi all,for all of you that have done an EFI conversion in their vehicles...which a/market vehicle speed sensor did you use and approx cost?
I have the T700 tranny in my HJ coupe which i currently use a switch for the TCC lock up and would like the ECU to take over.
Kalmaker have one @$115.00...What others are there?
Cheers ...mario
#2 Posted : Tuesday, 9 October 2007 4:21:21 PM(UTC)
Mario
Use the Kalmaker one. In a standard VN/VP the speed sensoe screws in the side of the box and puts out 10 pulses per rev for the speedo. Inside the VN/P speedo the electronics converts the signal to 2 pulses per rev for the ECU and cruise control.
mmazz30 Offline
#3 Posted : Wednesday, 10 October 2007 5:28:43 AM(UTC)
mmazz30
Thanks Byron,
I have all that you mentioned and i am using the AT29c256 chip so i can stack the files to run my LPG once i have it hooked up.
I am trying out different cals at the moment to gauge the differences on my EFI project that i made up.
Surpri
