How do you tell a Saginaw Gearbox? I have a Box all it has on the side is Holden 6 stamped thats it...Hope someone can help.
Matt.
Saginaw has reverse selector on the sideplate with the 1-2 and 3-4 selectors. Also has a cast iron extension housing. Muncie and Aussie 4 speeds have reverse selector on the extension housing. Muncie has full alloy case and extension, Aussie has cast iron |
