#1 Posted : Friday, 12 October 2007 4:28:17 PM(UTC)
Hi,
I have a EA Falcon at 100 kph it develops a slight shudder vibration thru the steering wheel and disappears at 105 kph etc.
I have fitted new wheel bearings had 3 wheels balances from different tyre,suspension shops and they all say the wheels are ok.
I have CSA mags fitted.
There is a slight brake disc warp vibration when the brakes are applied, is it at all possible that a warped disc may cause a steering vibration.
All 3 tyre shops could not honestly answer my question.
Thank you
#2 Posted : Friday, 12 October 2007 9:01:48 PM(UTC)
My EB shudders under brakes even after brand new rotors were fitted. I have narrowed it down to the lower control arm inner bushes being completely flogged out.
Your shudder sounds like a balance problem maybe you need to get your wheels balanced on
6pak Offline
#3 Posted : Saturday, 13 October 2007 8:21:25 AM(UTC)
6pak
My old EA had a similar problem which eventually revealed itself when the tyre carcasses started to separate as the tyres themselves were dodgy (on the car when i bought it). Just as a suggestion try rotating the rear tyres to the front and see what happ
#4 Posted : Sunday, 14 October 2007 3:12:23 AM(UTC)
Then drive at 99.
