coley13 Offline
#1 Posted : Saturday, 13 October 2007 2:22:03 AM(UTC)
coley13
are the chassis different from the ute to one tonner? also what versions eg, hq to wb are interchangable with parts. if for example the chassis is the same and i was to put a cab of a different model to convert to a 1 tonner would i have registration issues
my utes pretty nice at the moment but its basically a work ute and it's not going to stay nice for long but when i've finsished my house i'd love to do up a 1 tonner but use as much as possible of what i already have
cheers craig
#2 Posted : Saturday, 13 October 2007 2:54:44 AM(UTC)
1-tonner chassis is longer by about 6 inches than ute/van. HQ-WB are basically the same, with some minor differences but not enough to make cabs and chassis interchangeable. I have a crack free late HX RTS chassis is you want one. Its currently rolling wi
#3 Posted : Saturday, 13 October 2007 2:54:44 AM(UTC)
1-tonner chassis is longer by about 6 inches than ute/van. HQ-WB are basically the same, with some minor differences but not enough to make cabs and chassis interchangeable. I have a crack free late HX RTS chassis is you want one. It's currently rolling w
musksell Offline
#4 Posted : Saturday, 13 October 2007 8:25:55 AM(UTC)
musksell
ho hum.... I thought the HZ came out with radial tuned suspension which was supposed to be 30% better then the HQ to HX ...??
In the real world something with a very heavy front end and light back end.....
your opinion.....>
#5 Posted : Sunday, 14 October 2007 1:07:59 AM(UTC)
The HZ does have RTS which is lots of things including relocated upper control arm mounts. All late HX's have the HZ upper control arm mountings, but the rest of the bits that make up RTS weren't introduced until HZ. As this is a late HX chassis it has th
#6 Posted : Sunday, 14 October 2007 1:07:59 AM(UTC)
The HZ does have RTS which is lots of things including relocated upper control arm mounts. All late HXs have the HZ upper control arm mountings, but the rest of the bits that make up RTS werent introduced until HZ. As this is a late HX chassis it has the
adam PERTH Offline
#7 Posted : Sunday, 14 October 2007 1:13:04 AM(UTC)
adam PERTH
6 inches longer..... Hmmmm
Bryon, whattya think about using the T350 long snout (6 inches longer than most Aus T350)
and a V8 Ute tailshaft into a 1 tonner??
sound like it may just work.
Yoke unis different of course.
A1 Bogan.
#8 Posted : Sunday, 14 October 2007 1:47:23 AM(UTC)
Sounds OK. Why not just use a normal TH350 and a normal tonner shaft though?
Duzty Offline
#9 Posted : Monday, 15 October 2007 1:27:51 AM(UTC)
Duzty
i have seen a couple of wellbody utes turned into tunnas with 1/4 panels or vise versa. it looks quite good. here is a pic i have of one
http://www.members.iinet.net.au/~rhodes/ill%20ute.jpg
[IMG]http://www.members.iinet.net.au/~rhodes/frontend.JPG[
