Fastlane
Holden Forums
Holden General Discussion
Factory Prem temp gauge wires hook up Help
Thanks Given:
I have hq 202 orginally now a 350chev . Ive taken my dash face plate off and tried to hook a factory hq prem or statesman Temp gauge
I cut the green one and pink one that go to the temp light and joined longer wires to them and plugged them into the gauge. I then earthed the gauge to the dash. but the gauge reads nothing. when I unearth it from the dash it goes to the far right just past H for the hottest.
Any suggestions what could be wrong?? Could it be the sensor is different in the block? if so would a hq 202 one fit in the hole??
Cheers in advance Keith
If its not broke it will be soon |
yes there are differant ones just the temp sender(light in the dash) and temp gauge sender (needle that goes cold to hot) just get one out of a prem or HZ-WB or go buy a new one from auto shop good luck
it's beer o'clock |
On The Other Hand There's Finger's |
its beer oclock |
Thanks Given:
I had the light in the dash but trying to swap for a gauge. but the gauge isnt working . im wondering if the sensor is the prob and if an hq one will fit the chev. or what I might do to make it work. I cut the green and pink wires and connected them to th |
If you had a light, that sender will not work for a gauge. The gauge is a scale of voltage returns, where a light is on/off (either maxed out, or not at all). The sender has to match the gauge, then put in appropriate adaptor to fit engine.
_________ |
__________________________________________ Keep the shiny side up, and the greasy side down. |
available at any Auto One or Rare Spares part # 7438478
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel free to message me. To shop o
Your light had a positive signal from the ignition and a wire to the sender. I assume the pink is ignition on as it is in most other holdens I have played with. The other wire would be green, going to the sender. The sende ris just an on/off switch
Som
Thanks Given:
The sender thats in the engine was there when I got the engine. I have no way of knowing whether it had a gauge or a light. So is what I need a sender from a holden that had a gauge or the one from Rarespares .. And will that sender fit the hole in my ma |
Yes you need a new sender, unless you want the needle to simply be cold or hot with nothing in between. Yes it is the same thread, switch sender was in say Monaro LS 350 and variable sender in Statesman and GTS plus LS with optional sports dash. Same goes
It will depend on the manifold whether the sender will fit.
I have had 3 different chev moanifolds, and all have had different sender threads. Cast iron unit - no adapter. Holley manifold, medium adapter. Australian performance manifold (can't rememb |
I have had 3 different chev moanifolds, and all have had different sender threads. Cast iron unit - no adapter. Holley manifold, medium adapter. Australian performance manifold (cant remembe |
3815936 - SENDER UNIT OIL PRESSURE HK-HQ WITH CHEV ENGINE - roughly $20
Thanks Given:
Sweet thanks for all the info guys I will beable to sort it out with what ive learned here cheers.
Dr Terry, Warren started talking about oil senders, so i thought i would post the info on it incase he needed it too....generally when i sell a temp sender, the customer buys a oil pressure sender too.
[IMG]http://www.members.iinet.net.au/~rhodes/front
Thanks Given:
Cheers ill buy that from Rarespares its not 20 here its 40 ouch lol. https://rsp-secure.com/rsnz/If its not broke it will be soon |
Thanks Given:
I rang rarespares to get a sender unit for the chev and they have them but they said I need an adaptor to fit it into that goes into the chev engine
They said these are no longer available any suggestions ??
A plumbing or engineering supplies shop may have the adaptors. All you need is the sender which is in there, and the one you want to fit. They should be able to find an adaptor to fift one to the other.
__________________________________________ Kee |
Keith, a suggestion. move to the great land of Aus! :)
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel free to message me. To shop onlin
Thanks Given:
I got my new sender today and fitted it but I may have cranked it down to tight, I was tryin to put it to the same level as the old one.. Hope I havent damaged it..
Any way I hooked it up and its only moving a little.. And that was while the engine wa |
Fastlane
Holden Forums
