BlaDe Offline
#1 Posted : Wednesday, 17 October 2007 5:39:18 AM(UTC)
BlaDe
Hey guys i have just got a 3.55 lsd salisbury and i was wanting to know can i just change the crown wheel and pinion gear to a different ratio ie a 3.08 or 3.36
Thanks Blade
#2 Posted : Wednesday, 17 October 2007 10:15:43 PM(UTC)
Yes, but only to 3.08, 3.36 or 4.44. 2.6 and 2.78 use a different hemisphere.
#3 Posted : Thursday, 18 October 2007 12:40:35 AM(UTC)
Hi Guys.
I know its rare, but there was a 3.90 Large Salisbury also.
Dr Terry.
#4 Posted : Thursday, 18 October 2007 12:40:35 AM(UTC)
Hi Guys.
I know it's rare, but there was a 3.90 Large Salisbury also.
Dr Terry.
musksell Offline
#5 Posted : Thursday, 18 October 2007 5:49:43 AM(UTC)
musksell
but how hard is it to do this....well within the means of the average home mechanic......I mean the LSD to LSD change......done the standard banjo.....?
BlaDe Offline
#6 Posted : Thursday, 18 October 2007 6:13:53 AM(UTC)
BlaDe
cheers guys i wil be putting the crown wheel on myself but will get a mech to put it all back in just in case, another small question do i need to change the pinion gear as well or can i just change the crown wheel?
Blade
#7 Posted : Thursday, 18 October 2007 6:25:48 AM(UTC)
You need to change them both, as a matched pair. Will need new collapsable spacer, new bearings, new seal etc. Costs a few hunder just in parts, and then it still may be noisy without lapping the gears.
_________________________________________________
#8 Posted : Thursday, 18 October 2007 6:34:40 AM(UTC)
Originally posted by Dr Terry
Hi Guys.
Dr Terry.
#9 Posted : Thursday, 18 October 2007 6:34:40 AM(UTC)
Hi Guys.
Dr Terry.
#10 Posted : Thursday, 18 October 2007 7:12:22 AM(UTC)
Hi Byron, Just reading this thread and noted you stated "Yes, but only to 3.08, 3.36 or 4.44. 2.6 and 2.78 use a different hemisphere"
I recently brought a Magnum disc brake LSD diff (2.6) and intended to fit 4.44 gear set, using the 2.6's hemisphere...
#11 Posted : Thursday, 18 October 2007 7:12:22 AM(UTC)
I recently brought a Magnum disc brake LSD diff (2.6) and intended to fit 4.44 gear set, using the 2.6s hemisphere... o
#12 Posted : Thursday, 18 October 2007 7:50:51 AM(UTC)
See if you can find a flogged out 3.08:1 or up LSD and buy a minispool for it. They are only about $120.
BlaDe Offline
#13 Posted : Thursday, 18 October 2007 10:30:38 AM(UTC)
BlaDe
lapping the gears?
Blade
#14 Posted : Thursday, 18 October 2007 4:07:29 PM(UTC)
Sometimes when gears have been in a particular diff they wear together. If you move then to a new housing they can be noisy. I had this happen to me with an LX Torana banjo. There was a company that used to (Im pretty sure the term was lap) do something t
#15 Posted : Thursday, 18 October 2007 4:07:29 PM(UTC)
Sometimes when gears have been in a particular diff they wear together. If you move then to a new housing they can be noisy. I had this happen to me with an LX Torana banjo. There was a company that used to (I'm pretty sure the term was lap) do something
#16 Posted : Thursday, 18 October 2007 6:21:02 PM(UTC)
[/quote]
Terry
Which model? I know its actually possible to build one using parts from other ratios but Ive never heard of a 3.9:1 Salisbury. Ive been wrong plenty of times before.....
Byron
____________________________________________________
#17 Posted : Thursday, 18 October 2007 6:21:02 PM(UTC)
[/quote]
Terry
Which model? I know it's actually possible to build one using parts from other ratios but I've never heard of a 3.9:1 Salisbury. I've been wrong plenty of times before.....
Byron
BlaDe Offline
#18 Posted : Thursday, 18 October 2007 7:25:53 PM(UTC)
BlaDe
cheers byron
#19 Posted : Tuesday, 23 October 2007 11:00:44 AM(UTC)
Just quickly... Byron or Dr. Terry
Are the axel splines the same in 2.6, 2.76 as in 3.08,3.36 and 4.44?
Thanks in advance
Steve
#20 Posted : Tuesday, 23 October 2007 4:00:21 PM(UTC)
Yes. Also the same as 28 spline 9" and VN on Borg Warner plus others.
