wildshotz Offline
#1 Posted : Friday, 19 October 2007 4:48:39 AM(UTC)
wildshotz
Hi all..
Has anyone mounted an electric fuel pump in the boot? Where and how? Do you think my idea will work.
Carter electric fuel pump with filter and regulator in series.
Tank>inline filter>fuel pump>regulator>carby.
My problem is where to mount the filter and pump as I have a twin system, hence no room near the tank. I was thinking of mounting them in the boot off the wheel arch using L brackets with a sheet of MDF or whatever on top with Filter and pump mounted inline underneath with fuel lines. Then hinges on the top sheet and another mounted as a door, so the whole set up is Boxed in, out of site and protected but still accessible. I have the holes for the fuel lines already drilled (used to have a gas system on top of the wheel arch in the boot)
Dave
wildshotz Offline
#2 Posted : Friday, 19 October 2007 4:51:14 AM(UTC)
wildshotz
Oh.. I forgot.
It's going into a Holden HZ Premier, very warm 308.
wildshotz Offline
#3 Posted : Friday, 19 October 2007 4:51:14 AM(UTC)
wildshotz
Oh.. I forgot.
Its going into a Holden HZ Premier, very warm 308.
HZ-GTS Offline
#4 Posted : Friday, 19 October 2007 5:03:41 AM(UTC)
HZ-GTS
pretty sure thats quite illegal todo ... now, in saying that, im personally making an alluminium drop tank with an efi pump inside it, feeding a surge tank, it will obviously have an overflow back into the tank, then mounting the carby fuel pump to the ba
OldSchool V8 Rumble
Mr Void Offline
#5 Posted : Saturday, 20 October 2007 9:40:27 PM(UTC)
Mr Void
I do NOT know the laws re this but I don't see any prob if it is 1)fully partitioned from the boot space and 2)vented to the outside of the car.
...but you might do well talking to a mechanic about it?? Hopefully someone on here knows.
____________
___________________
Mr Void Offline
#6 Posted : Saturday, 20 October 2007 9:40:27 PM(UTC)
Mr Void
I do NOT know the laws re this but I dont see any prob if it is 1)fully partitioned from the boot space and 2)vented to the outside of the car.
_____________
___________________
HZ-GTS Offline
#7 Posted : Sunday, 21 October 2007 9:29:20 PM(UTC)
HZ-GTS
Or you could ring up the RTA ... get something in writing and you're set
OldSchool V8 Rumble
OldSchool V8 Rumble
HZ-GTS Offline
#8 Posted : Sunday, 21 October 2007 9:29:20 PM(UTC)
HZ-GTS
Or you could ring up the RTA ... get something in writing and youre set
OldSchool V8 Rumble
OldSchool V8 Rumble
This page was generated in 0.088 seconds.
