tenticles Offline
#1 Posted : Monday, 22 October 2007 4:29:36 AM(UTC)
tenticles
hiya all
the more i delve into home tuning my lpg/petrol ute ( 253 auto HQ impco system on 350 holley ), the more confused i become
i am reading posts which say LPG needs more advance coz of its theoretical higher octane ...
and i am reading posts which say LPG needs less advance coz it burns hotter/faster
and i dont know who to believe, but i sure wouldn't trust my installer ( should have known when he said "i've never worked on a carburetted car before ")
so please help a poor dual fueler, and put him out of his misery
yes sonny, it's an HQ ute
#2 Posted : Monday, 22 October 2007 4:51:50 AM(UTC)
LPG needs more initial advance at lower RPM, but less total advance at higher RPM.
vintageholden Offline
#3 Posted : Monday, 22 October 2007 9:10:51 AM(UTC)
vintageholden
the problem with duel fuel is can can only really get one or the other working properly
gas needs more advance set you car up for straight gas and only switch to petrol for emergency if you get the petrol running good gas will be crap and ping all the ti
#4 Posted : Thursday, 13 December 2007 8:21:37 AM(UTC)
im running straight gas have a impco 450 on a rochester base plate and elec dizzy the question i ask is how do u set the more intial timing at lower rpm and and less total advance at higher rpm plz explain commodorenut
mrhj253 Offline
#5 Posted : Thursday, 13 December 2007 8:23:57 AM(UTC)
mrhj253
sorry it was me who dont the last post forgot to sign in plz help with the timing question
jump on if you want a holdon
peter_flane Offline
#6 Posted : Thursday, 13 December 2007 8:56:46 AM(UTC)
peter_flane
#7 Posted : Thursday, 13 December 2007 4:13:54 PM(UTC)
You need to get the distributor regraphed for less centrifugal advance, limit the vacuum advance and set the static timing to suit LPG.
If we all had the same (good) taste, who would buy all the
BrianH Offline
#8 Posted : Saturday, 15 December 2007 11:24:31 PM(UTC)
BrianH
tenticles
There is not much you can do to home tune a LPG car apart from playing around with the gas mixture at idle and cruising speeds. Even then you can make it worse if you are not experienced. Gas is a fairly high octane fuel and it burns a litt
Edited by user Saturday, 15 December 2007 11:26:04 PM(UTC)  | Reason: Not specified
#9 Posted : Sunday, 16 December 2007 12:53:40 AM(UTC)
I fitted the electronic ignition to the 202 HQ, tuned it to petrol, took 40thou off the head to give around 10:1, ran the mid grade or high octane ULP,would not run on standard ulp, motor nearly died when I accidentally put standard ulp in, had no problem
BrianH Offline
#10 Posted : Sunday, 16 December 2007 6:48:33 AM(UTC)
BrianH
John
I think you will find that the computer in the VN/VP etc does not have a separate program for petrol and gas. I bought a straight gas system from Impco for a VP engine in another car (Impco supplied the factory system) and was told to use the sto
#11 Posted : Sunday, 16 December 2007 8:40:10 AM(UTC)
I think it was Kalmaker who used to do the dual program VN/VP memcal, where you could flick between 2 programs (say 1 set up for 98RON & 1/4 mile passes, whilst the other set up for 91RON & the daily commute).
Might be worth investigating for dual fuel.
#12 Posted : Sunday, 16 December 2007 9:27:43 AM(UTC)
Sorry I did not mean the Vn etc computer would do the dual fuel from standard, the computer does need to be programmed for the dual use. It has the capacity to be so programmed.
#13 Posted : Sunday, 17 August 2008 3:52:03 AM(UTC)
Hi just wonderin if you can tell me what my 350 chev should be timed at to run on LPG?
Thanx man
#14 Posted : Sunday, 17 August 2008 5:08:44 PM(UTC)
the economical way of sorting it out would be get a cam profile to suit straight gas, a good cam will also come with an advised distributor advance curve, this is farily generic but alot bette rthan a standard bump stick and a twist of the dizy
