HQLDEN Offline
#1 Posted : Tuesday, 23 October 2007 4:11:21 AM(UTC)
HQLDEN
I just bought a blue 253 out of a vk to vl Commodore which was supposed to be a Police Pursuit motor . I know nothing about this engine except that the eng. no. is VR 255875 . In QLD we had Yellow Police Pursuit Commodores which were a special issue . Could anyone please tell me if ....* there is any advantage in one of these engines over a 253 Red motor out of a HQ-Hx ?....*Was there anything special about these engines ?....Would this motor be suitable for a 1973 HQ Coupe with a stock Trimatic and a 3.08 LSD ?
PLEASE DON"T SUCK THE YELLOW SNOW
CHANGE IS INEVITABLE , EXCEPT FROM VENDING MACHINES
#2 Posted : Tuesday, 23 October 2007 4:21:16 AM(UTC)
A VR prefixed 253 is just a normal blue 253. Only advantage over a red 253 is the 4BBL manifold and HEI dizzy. In fact you will be better off with a red 253 out of a HT-HJ to avoid having to fit ADR27A or worse pollution equipment. Just fit a pre pollutio
#3 Posted : Tuesday, 23 October 2007 4:56:40 AM(UTC)
With that engine number sequence, that motor is from a VC or extremely early VH (more likely a late VC).
You can confirm it from the casting date on the front of the block, above the water pump, on the flat section behind the heater hose, below the the
HQLDEN Offline
#4 Posted : Tuesday, 23 October 2007 6:33:20 AM(UTC)
HQLDEN
Thanks Byron,fortunately I didn't pay much for the motor so no harm done .As you say , I'll stick to my HQ red motor and fit the 4 barrel manifold and quadrajet . The hei dizzy you mention ,is that better than an aftermarket electronic distributor as the
HQLDEN Offline
#5 Posted : Tuesday, 23 October 2007 6:33:20 AM(UTC)
HQLDEN
Thanks Byron,fortunately I didnt pay much for the motor so no harm done .As you say , Ill stick to my HQ red motor and fit the 4 barrel manifold and quadrajet . The hei dizzy you mention ,is that better than an aftermarket electronic distributor as the bl
#6 Posted : Tuesday, 23 October 2007 4:12:54 PM(UTC)
It depends on the aftermarket dizzy. You'll be able to use the Quaddy that came with the blue motor, but you'll have to get an earlier 4 barrel manifold as the blue one won't fit. You'll also have to fit a manual choke conversion.
_____________________
#7 Posted : Tuesday, 23 October 2007 4:12:54 PM(UTC)
It depends on the aftermarket dizzy. Youll be able to use the Quaddy that came with the blue motor, but youll have to get an earlier 4 barrel manifold as the blue one wont fit. Youll also have to fit a manual choke conversion.
_________________________
