YetAnotherForum.NET Help
2 Pages<12
#21 Posted : Friday, 26 October 2007 7:44:59 PM(UTC)
Hi Byron, ebay would still pull your example. They have low tolerance for anything resembling VIN sales
#22 Posted : Friday, 26 October 2007 9:25:52 PM(UTC)
What surprises me is that the authorities that deem a vehicle a statutory write off could just trawl sites such as eBay for these listings then simply and immediately add these VIN numbers to the stat writeoff list yet they don't.
This way these pl
#23 Posted : Friday, 26 October 2007 9:25:52 PM(UTC)
What surprises me is that the authorities that deem a vehicle a statutory write off could just trawl sites such as eBay for these listings then simply and immediately add these VIN numbers to the stat writeoff list yet they dont.
This way these pla
#24 Posted : Friday, 26 October 2007 10:11:44 PM(UTC)
#25 Posted : Friday, 26 October 2007 10:58:03 PM(UTC)
Yep. Someone used a bit of a trick a couple of weeks ago and it went through to completion. HG shell with HK tags. They dont care as long as there is a car-shaped lump of steel attached to the tags. I like Gregs "with car attached". Very glib.
#26 Posted : Friday, 26 October 2007 10:58:03 PM(UTC)
Yep. Someone used a bit of a trick a couple of weeks ago and it went through to completion. HG shell with HK tags. They dont care as long as there is a car-shaped lump of steel attached to the tags. I like Greg's "with car attached". Very glib.
#27 Posted : Friday, 26 October 2007 11:52:26 PM(UTC)
Cut and shut firewall is how you re-birth an HD to HG Holden. The problem is where did you get the replacement "body" from.
You could also do it with an HQ to WB, just cut and shut the cowl area and change the chassis and engine, body has changed. I do
classic oz wreck Offline
#28 Posted : Saturday, 27 October 2007 12:05:01 AM(UTC)
classic oz wreck
generally if a car is over 15 years old the insurance companies will list it as a repairable write off no matter how bad it is..unless its burnt..the law only applies to cars 15 years and newer for stat write off..
Edited by user Saturday, 27 October 2007 12:05:37 AM(UTC)  | Reason: Not specified
www.classicozwreck.com.au
#29 Posted : Monday, 29 October 2007 12:45:48 PM(UTC)
Wierd isn't it. If I sold the rustiest shell on earth with tags it'd be OK though.
#30 Posted : Monday, 29 October 2007 12:45:48 PM(UTC)
Wierd isnt it. If I sold the rustiest shell on earth with tags itd be OK though.
#31 Posted : Monday, 29 October 2007 4:38:27 PM(UTC)
This shell does not actually have any tags on it, so what you have is a photo of a car, that you do not get, and a set of tags. The car does actually have a firwall. So the person is selling tags only. But close to what Byron said in the first place.
#32 Posted : Monday, 29 October 2007 9:12:51 PM(UTC)
Gone already. That trick didnt work...
#33 Posted : Monday, 29 October 2007 9:12:51 PM(UTC)
Gone already. That trick didn't work...
Guest (5)
2 Pages<12
This page was generated in 0.080 seconds.
