jayHK69 Offline
#1 Posted : Friday, 26 October 2007 2:00:19 AM(UTC)
jayHK69
hi, i have a th350 that was behind a 307
this will now be going behind a 350
my question is: it has a 153 tooth flexplate
which needs replacing, do i have to stick with the
same amount of teeth or can i go up to the 168 tooth ?
jayson
Handgunner Offline
#2 Posted : Saturday, 27 October 2007 8:26:05 AM(UTC)
Handgunner
Stay with 153 tooth as it matches your starter Motor Pinion gear....
I am using one on my 307 w/turbo 400...
Hope this helps....cheers ..
Are you hoping to use the 168 to gain some more cranking torque?
If you are i think that you will need to use a
Bang Bang
jayHK69 Offline
#3 Posted : Sunday, 28 October 2007 6:44:11 AM(UTC)
jayHK69
thanks handgunner, makes sense i sort of thought that might have been the case
jayson
