#1 Posted : Saturday, 27 October 2007 7:28:52 AM(UTC)
Does anyone know by how many degrees, a 202 cam would be retarded. If one was to set it one tooth out.
Cheers.
vintageholden Offline
#2 Posted : Saturday, 27 October 2007 8:35:25 AM(UTC)
vintageholden
depnds what tooth you talking about
i keyway out is - or + 2 degrees if you have adjustable gear
3 teeth out is - or + 2 degrees so 1 tooth is about 1/2 a degree
i can email photos if wanted
IMG]http://i175.photobucket.com/albums/w156/vintagehold
Edited by user Saturday, 27 October 2007 8:41:43 AM(UTC)  | Reason: Not specified
Handgunner Offline
#3 Posted : Saturday, 27 October 2007 8:47:45 AM(UTC)
Handgunner
While on this topic of 202 cams... should i advance my camshaft on my 202 for use with gas? I am going to use a 186 cam , as my 202 cam is way too big and has to come out... and i read somewhere that a 186 standard grind is very suitable for gas ?
My 20
Bang Bang
#4 Posted : Saturday, 27 October 2007 8:56:15 AM(UTC)
vintageholden
definatly ...just the dizzy will do......
i have the same setup
202 blue with vk efi manifold standard throtle body with gas ring
i have 3.55 as well.......
get a blue motor dizzy
gas neads a good spark
#5 Posted : Saturday, 27 October 2007 9:19:27 AM(UTC)
Thanks vintageholden. But I wasn't meaning the keyway. I was meaning one gear tooth of the cam gear(not multi keyway crank gear). I'm guessing it's going to be around the 15 degree mark. But I want to know for sure.
Handgunner, you should start your own
#6 Posted : Saturday, 27 October 2007 9:19:27 AM(UTC)
Thanks vintageholden. But I wasnt meaning the keyway. I was meaning one gear tooth of the cam gear(not multi keyway crank gear). Im guessing its going to be around the 15 degree mark. But I want to know for sure.
Handgunner, you should start your own thr
adam PERTH Offline
#7 Posted : Saturday, 27 October 2007 9:00:42 PM(UTC)
adam PERTH
Adv. cam timing will give more down low, less up top
Retarted cam timing will give less down low and, more up top.
A1 Bogan.
#8 Posted : Saturday, 27 October 2007 10:30:48 PM(UTC)
Adam, yer , low down is what i am after...cheers, sorry for hijacking the thread :)
#9 Posted : Monday, 29 October 2007 10:00:09 PM(UTC)
You cant use a 186 cam in a 202. The rod bolts will hit the cam, unless its actually a 202 cam in a 186.
#10 Posted : Monday, 29 October 2007 10:00:09 PM(UTC)
You can't use a 186 cam in a 202. The rod bolts will hit the cam, unless it's actually a 202 cam in a 186.
Handgunner Offline
#11 Posted : Tuesday, 30 October 2007 7:15:51 AM(UTC)
Handgunner
Thank you Byron, you have saved me some trouble there, i really appreciate it :), the cam is in , but the lifters and rockers are still not in, so out it will now come..... it would of been quite stressfull starting that one up...lol... ok... so now i nee
Bang Bang
#12 Posted : Monday, 21 July 2008 4:46:54 AM(UTC)
Please dont get a regrind there a waste of money get a brand new cam with a name you can trust be verry wary about cheep ones on ebay its better to get a good one rather than a regrind or a cheapie
HQforme Offline
#13 Posted : Monday, 21 July 2008 4:52:21 AM(UTC)
HQforme
Are these recommendations factoring in advance ground on the cam, if any? I've heard that some are designed for advance if you just "line up the dots" whereas others are meant to be set to your specs. Suppose it all depends which one you order...and the b
"Silly modern cars"
HQforme Offline
#14 Posted : Monday, 21 July 2008 4:52:21 AM(UTC)
HQforme
Are these recommendations factoring in advance ground on the cam, if any? Ive heard that some are designed for advance if you just "line up the dots" whereas others are meant to be set to your specs. Suppose it all depends which one you order...and the be
"Silly modern cars"
