HQforme Offline
#1 Posted : Monday, 29 October 2007 10:41:04 AM(UTC)
HQforme
How do i go about it? Im assuming it's just a case of looking for an appropriate suffix or prefix?
Cheers.
"Silly modern cars"
#2 Posted : Monday, 29 October 2007 4:15:44 PM(UTC)
Was thanked: 559 time(s) in 534 post(s)
Look at the prefix and compare to my website www.monaroparts.com engine number list.
JBM Offline
#3 Posted : Tuesday, 30 October 2007 6:11:09 AM(UTC)
JBM
A high comp 202 will have an #L..... prefix and was the common 202 used for domestic built cars and the low comp motor is #M.... and was manly used for export.
egs; JL - LJ; HL - LH, LX and UC; XQL - UC, QL - HQ, HJ, HX, and early HZ; ZL - HZ; VL - VB,
Edited by user Tuesday, 30 October 2007 6:18:09 AM(UTC)  | Reason: Not specified
ozjason Offline
#4 Posted : Tuesday, 30 October 2007 10:56:16 PM(UTC)
ozjason
Correct me if Im wrong, but the only difference between LC and HC was the head used, right? So after 30 years, an engine may not have the same head and even if it does, its not a given that it hasnt been rebuilt somewhere along the years. So if youre wo
ozjason Offline
#5 Posted : Tuesday, 30 October 2007 10:56:16 PM(UTC)
ozjason
Correct me if I'm wrong, but the only difference between LC and HC was the head used, right? So after 30 years, an engine may not have the same head and even if it does, it's not a given that it hasn't been rebuilt somewhere along the years. So if you'r
#6 Posted : Tuesday, 30 October 2007 11:17:26 PM(UTC)
Was thanked: 219 time(s) in 199 post(s)
#7 Posted : Tuesday, 30 October 2007 11:17:26 PM(UTC)
#8 Posted : Wednesday, 31 October 2007 12:07:49 AM(UTC)
Terry
I think the 138 used different pistons too, but that's just from memory.
#9 Posted : Wednesday, 31 October 2007 12:07:49 AM(UTC)
Terry
I think the 138 used different pistons too, but thats just from memory.
#10 Posted : Wednesday, 31 October 2007 12:59:03 AM(UTC)
Hi Byron.
Yes, 138 (& 130) Reds used domed pistons to maintain a reasonably high compression with the std 149/161/173 type head. There are no lo-comp versions of these 2 little motors.
Dr Terry.
#11 Posted : Wednesday, 31 October 2007 1:58:28 AM(UTC)
Terry
Agree on the 130 (CA, QA etc), but what about the 2250L, CC and HC engines. These were all 138 low compression. That is why the 173 were D and E prefixes as the 130 high comp was A, 138 high comp B and low comp C.
I thought the 138 used the same
HQforme Offline
#12 Posted : Wednesday, 31 October 2007 2:21:30 AM(UTC)
HQforme
Cheers for the responses.
I know the motors been replaced with what appears to be an unfettled 202. Not that it matters much as im just bolting the bottom end together after a full rebuild. Bored, cammed and twin carbied now.
It was more a point of
"Silly modern cars"
HQforme Offline
#13 Posted : Wednesday, 31 October 2007 2:21:30 AM(UTC)
HQforme
I know the motor's been replaced with what appears to be an unfettled 202. Not that it matters much as i'm just bolting the bottom end together after a full rebuild. Bored, cammed and twin carbied now.
"Silly modern cars"
#14 Posted : Wednesday, 31 October 2007 3:04:43 AM(UTC)
Originally posted by Byron Rich
Terry
ozjason Offline
#15 Posted : Wednesday, 31 October 2007 8:19:19 PM(UTC)
ozjason
Thanks for the clarification, guys. Looks like I was only half right. :-)
Jason.
HQforme Offline
#16 Posted : Thursday, 1 November 2007 2:17:52 AM(UTC)
HQforme
HC it is indeed.
Byron, thats a great little site youve got there. Best of luck in achieving your goals :-)
"Silly modern cars"
HQforme Offline
#17 Posted : Thursday, 1 November 2007 2:17:52 AM(UTC)
HQforme
HC it is indeed.
Byron, that's a great little site you've got there. Best of luck in achieving your goals :-)
"Silly modern cars"
