80737k Offline
#1 Posted : Wednesday, 31 October 2007 11:48:50 PM(UTC)
80737k
G'day fellas, I'm pulling a dash out of an XC but am having all sorts of drama trying to get the light switch out..No bloody room up under there :-(
Not much you's can help with the squish situation but could you tell me if it has a pin to push in as per XY's ?
Also, How do you tell if a XC van is a sundowner? This one has a full headlining, plus it has a tacho dash which has me thinking.
Finally, Are p/van doors the same as coupes?
Thanking you
"Junk is something you throw out three weeks before you need it"
Fossil fuels are YUMMY !
#2 Posted : Thursday, 1 November 2007 12:25:21 AM(UTC)
Yeah, there's a little plastic button you have to press to get the knob and rod out of the switch housing, then you can undo the nut and remove the switch. the "button" is on the side of the plastic switch housing, cant remember which side, you have to p
80737k Offline
#3 Posted : Thursday, 1 November 2007 12:35:07 AM(UTC)
80737k
Thanks Nathan, He he, I broke the damned thing (was fragile, as you said). I'm wrecking the van anyway and was just wanting to get the tacho dash out. A scrappie mate dropped it off and said i can strip out anything i want if i get the gas tank out for hi
Paul351xb Offline
#4 Posted : Thursday, 1 November 2007 8:48:41 AM(UTC)
Paul351xb
In regards to the panelvan doors, yes they are the same as coupes and utes. Only the glass is different. What motor was in the car? Has it still got the GS bonnet, spotties and grille or are they long gone? It might even have the black satin flip fuel
80737k Offline
#5 Posted : Friday, 2 November 2007 12:21:48 AM(UTC)
80737k
G'day Paul, Sundowner or not, there's no saving this rust bucket :-(
It has been a work truck for a horse breaker for a lot of years and was never looked after/valued.
It's got a X-flow and T.bar auto, BW diff. Has the flip fuel cap, Tacho dash, fluted
Edited by user Friday, 2 November 2007 12:33:26 AM(UTC)  | Reason: Not specified
This page was generated in 0.065 seconds.
