Fastlane
Holden Forums
Holden General Discussion
Warrick yellow Bathurst HK GTS Monaro 327 or not?
Joined: 29/07/2006(UTC) Posts: 766 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
How can you tell by the plates if it was a Bathurst car? What do you think these plates are worth? Can someone re-birth with these plates and make a half-million dollar car? http://cgi.ebay.com.au/w...150176855427#descriptionRigPig 59-Cadillac CoupeDeville, 49-Triumph SpeedTwin, 74-HQ GTS4 Monaro
It's an original Warwick Yellow with Parchment/Black trim GTS327. And yes it could easily be rebirthed if it comes with the original chassis number. Or you are lucky enough to find a good Monaro shell with a VIN close to those plates from the same plant s |
Its an original Warwick Yellow with Parchment/Black trim GTS327. And yes it could easily be rebirthed if it comes with the original chassis number. Or you are lucky enough to find a good Monaro shell with a VIN close to those plates from the same plant so |
anything is worth what people will pay for it, the plates will probably end up on a replica 327 car and then sold as the real deal. some people have too much money ! I wish I did !
You cannot simply put plates on cars as they are can be dated, I recently looked at a car for a fellow and the body was 7/68 and the tags were 12/68. Now most people would not pick it, but it can be done.
There are also a large number of "reproduction"
as warren said it could be done if you know the in,s and out,s of em easy to stuff it up as well. only a fool would pay big money for a car only based on the tags alone?????? i know i would be checking further??
its certainly big business now,... building a faker. I sell alot of stuff to guys, who,, you know are doing it.. I have heard of guys faking the sales documentation as well.
A1 Bogan. |
Joined: 1/03/2005(UTC) Posts: 241  ![Australia Australia]() Thanks: 3 times
This is the reason i am currently going through a hassle to get my Hk Monaro registered. I have a Chev engine in it and when it was recod the block was decked, in doing so it took the engine # off. I informed vicroads of this prior to the set date of re r |
Jesse Jesse Jesse, you've not got a sense of humour! |
This is the reason i am currently going through a hassle to get my Hk Monaro registered. I have a Chev engine in it and when it was reco'd the block was decked, in doing so it took the engine # off. I informed vicroads of this prior to the set date of re |
Hi I HAD 3 OR 4 ENGINES DECKED, PUT IN CARS AND BOATS PASSED OK . WHEN DECKED THE ENGINE RECONDTION STATED NOs ON THE BILL WHAT HE HAD MACHINED OFF. I STAMPED THE VP NUMBERS ON THE ENGINE. PS SHOULD PUT THE NOs BACK ON THE BLOCK. SOME OF THE RTA HAVE
Fastlane
Holden Forums
