#1 Posted : Friday, 2 November 2007 9:28:01 AM(UTC)
How can you tell by the plates if it was a Bathurst car?
What do you think these plates are worth?
Can someone re-birth with these plates and make a half-million dollar car?
http://cgi.ebay.com.au/w...50176855427#description
59-Cadillac CoupeDeville, 49-Triumph SpeedTwin, 74-HQ GTS4 Monaro
#2 Posted : Friday, 2 November 2007 4:08:44 PM(UTC)
It's an original Warwick Yellow with Parchment/Black trim GTS327. And yes it could easily be rebirthed if it comes with the original chassis number. Or you are lucky enough to find a good Monaro shell with a VIN close to those plates from the same plant s
#3 Posted : Friday, 2 November 2007 4:08:44 PM(UTC)
Its an original Warwick Yellow with Parchment/Black trim GTS327. And yes it could easily be rebirthed if it comes with the original chassis number. Or you are lucky enough to find a good Monaro shell with a VIN close to those plates from the same plant so
#4 Posted : Friday, 2 November 2007 4:15:58 PM(UTC)
anything is worth what people will pay for it, the plates will probably end up on a replica 327 car and then sold as the real deal.
some people have too much money ! I wish I did !
#5 Posted : Friday, 2 November 2007 4:51:30 PM(UTC)
You cannot simply put plates on cars as they are can be dated, I recently looked at a car for a fellow and the body was 7/68 and the tags were 12/68. Now most people would not pick it, but it can be done.
There are also a large number of "reproduction"
petaus Offline
#6 Posted : Friday, 2 November 2007 5:58:29 PM(UTC)
petaus
as warren said it could be done if you know the in,s and out,s of em easy to stuff it up as well.
only a fool would pay big money for a car only based on the tags alone?????? i know i would be checking further??
adam PERTH Offline
#7 Posted : Friday, 2 November 2007 7:44:51 PM(UTC)
adam PERTH
its certainly big business now,... building a faker.
I sell alot of stuff to guys, who,, you know are doing it..
I have heard of guys faking the sales documentation as well.
A1 Bogan.
Bluez Offline
#8 Posted : Saturday, 3 November 2007 4:28:02 AM(UTC)
Bluez
This is the reason i am currently going through a hassle to get my Hk Monaro registered. I have a Chev engine in it and when it was recod the block was decked, in doing so it took the engine # off. I informed vicroads of this prior to the set date of re r
Jesse Jesse Jesse, you've not got a sense of humour!
Bluez Offline
#9 Posted : Saturday, 3 November 2007 4:28:02 AM(UTC)
Bluez
This is the reason i am currently going through a hassle to get my Hk Monaro registered. I have a Chev engine in it and when it was reco'd the block was decked, in doing so it took the engine # off. I informed vicroads of this prior to the set date of re
antoni Offline
#10 Posted : Saturday, 3 November 2007 9:58:28 AM(UTC)
antoni
Hi I HAD 3 OR 4 ENGINES DECKED, PUT IN CARS AND BOATS
PASSED OK . WHEN DECKED THE ENGINE RECONDTION STATED NOs ON THE BILL
WHAT HE HAD MACHINED OFF. I STAMPED THE VP NUMBERS ON THE ENGINE.
PS SHOULD PUT THE NOs BACK ON THE BLOCK.
SOME OF THE RTA HAVE
Guest (11)
