The Yeti Offline
#1 Posted : Friday, 2 November 2007 10:06:52 PM(UTC)
The Yeti
Hi I havent been arround for a while, Im buildign a 37 Chev as a rod, I have a 253 and traumatic to slot in her, Y a 253 and not a 308 or an actual chev thats a good question, well put simply I have it so it's goen in it already has Yella Terra heads on it and a 4bbl duel plane manifold, it's in sound condidion so what should I do to her just to giver her a little more punch what cam speck should I run for conventional 91ron ULP?
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
#2 Posted : Saturday, 3 November 2007 1:29:50 AM(UTC)
buy a copy of max ellerys how to rebuild and hot rod the holden v8 tells you everything aqround 40$ at super cheap or just parts mag add for book sales cheers
The Yeti Offline
#3 Posted : Saturday, 3 November 2007 1:40:12 AM(UTC)
The Yeti
thanks John will do
#4 Posted : Saturday, 3 November 2007 3:20:27 AM(UTC)
If its be rebuilt with YT heads it should have a decent cam already. Just stick on a blue 253 Quadrajet, blue HEI dizzy and extractors. It is unlikely itll run on 91 octane as most red motors were over 9:1 compression, so youll probably have to run 95/96.
Edited by user Saturday, 3 November 2007 4:55:07 AM(UTC)  | Reason: Not specified
#5 Posted : Saturday, 3 November 2007 3:20:27 AM(UTC)
If it's be rebuilt with YT heads it should have a decent cam already. Just stick on a blue 253 Quadrajet, blue HEI dizzy and extractors. It is unlikely it'll run on 91 octane as most red motors were over 9:1 compression, so you'll probably have to run 95/
adam PERTH Offline
#6 Posted : Saturday, 3 November 2007 3:25:44 AM(UTC)
adam PERTH
SIg Erson TQ 20 would be good for your application.
A1 Bogan.
bundybluedog Offline
#7 Posted : Saturday, 3 November 2007 10:19:26 AM(UTC)
bundybluedog
It will only run properl on 91ulp if its low compression. if its a hotrod you probbaly wont drive it everday anyways so stick to the 95 oct. TQ20 is a good cam
antoni Offline
#8 Posted : Saturday, 3 November 2007 10:25:17 AM(UTC)
antoni
Hi HAVE YELLA TERRA GOT HARDEN SEATS?
WILL NEED WITH THE FUELS WE HAVE NOWER DAYS.
THANKS TONY
This page was generated in 0.175 seconds.
