keithholden Offline
#1 Posted : Monday, 5 November 2007 4:45:27 AM(UTC)
keithholden
http://img402.imageshack...hp?image=mvc021fkn2.jpg
I took my thermostat housing off, least im sure thats where it goes.
None in there do you think I should run one or not??
HQ 350 Th400 with 3 core radiator flex fan with shroud :)
#2 Posted : Monday, 5 November 2007 6:51:50 AM(UTC)
Hi Keith.
This probably why your engine temp reads so low, because it is low.
Its not good for a motor to ever run without a thermostat, put a new one in, theyre not that expensive.
Dr Terry.
#3 Posted : Monday, 5 November 2007 6:51:50 AM(UTC)
Hi Keith.
It's not good for a motor to ever run without a thermostat, put a new one in, they're not that expensive.
Dr Terry.
#4 Posted : Monday, 5 November 2007 6:58:10 AM(UTC)
Yep that's where it goes. Any if you don't run one you'll have overheating problems and a worn out engine in a year.
#5 Posted : Monday, 5 November 2007 6:58:10 AM(UTC)
Yep thats where it goes. Any if you dont run one youll have overheating problems and a worn out engine in a year.
#6 Posted : Monday, 5 November 2007 7:18:07 AM(UTC)
people seem to think it will fix there over heating problems by taking the mout but it doesnt, in fact it can make it worse as the water wil move too fast so the enigne cant wash off the heat, wack one back in it, I also take the little nippel out and dri
keithholden Offline
#7 Posted : Monday, 5 November 2007 7:35:58 AM(UTC)
keithholden
Sweet ill buy one tomorrow. Im glad I checked :)
keithholden Offline
#8 Posted : Monday, 5 November 2007 7:40:17 AM(UTC)
keithholden
This may sound like a silly question but which way up do I put the thermostat or doesnt it matter?
#9 Posted : Monday, 5 November 2007 4:06:48 PM(UTC)
Hi Keith.
Spring to the bottom.
Dr Terry.
keithholden Offline
#10 Posted : Tuesday, 6 November 2007 6:10:43 AM(UTC)
keithholden
All back together. Just have to run the car tomorrow, let it warm up check for leaks and see how my gauge goes.
Cheers.
