bundybluedog Offline
#1 Posted : Monday, 5 November 2007 9:09:04 AM(UTC)
bundybluedog
My wife drives a VL commodore and recentlyu started to cough and sputter at idle and if you put your foot down it hesitates and wont accelerate properly its like it has a leed removed but all that is new. i read the computer and it said airflow meter and crank angle sensor, which i replaced and did not change a thing. i put a new computer in and that made it worse(its auto and i put an auto computer in). also while i drive all the lights on the computer constantly flash and if i put my foot down which is when it really plays up all the lights on it go out? some days it wont idle unless the aircon is on and puting some load on the engine? somedays it idles perfect and drives nice.
Can somone help im going crazy and mechanics are no help!!
All injectors are working.
#2 Posted : Monday, 5 November 2007 4:09:19 PM(UTC)
Hi bundeybluedog.
The most common item causing these issues on a VL is the air mass meter.
The once smooth & reliable VL Nissan 6-cylinder has proved to be a very unreliable heap of sh#t when they get old,
HQ SAND MAN Offline
#3 Posted : Monday, 5 November 2007 8:04:01 PM(UTC)
HQ SAND MAN
Hey mate. I can possibly help as i have a vl that was doing exctly the same thing,untill it stopped all together yesterday lol!! I am going to find out today whats wrong with it ,, the mechanic that briefly looked at it yesterday recons the crank angle se
#4 Posted : Monday, 5 November 2007 8:24:32 PM(UTC)
Hi Guys.
What you say HQ Sand Man is all possible. All these items & more give dramas on VLs, but the symptoms he gave (hesitation) leads me to think it is the air mass meter.
HQ SAND MAN Offline
#5 Posted : Monday, 5 November 2007 10:59:35 PM(UTC)
HQ SAND MAN
Hey Doc ,,! does that mean that my air mass has probably let go as well, mine is on gas and has all the same problems as the one described,, but mine was having alot of trouble starting and then misses alot sometimes under load and other times runs ok ??
#6 Posted : Monday, 5 November 2007 11:03:05 PM(UTC)
Hi Guys.
Yes, an LPG backfire will destroy a hot wire air mass sensor.
HQ SAND MAN Offline
#7 Posted : Monday, 5 November 2007 11:22:11 PM(UTC)
HQ SAND MAN
Cheers Doc ... Would that be the cause of not starting on gas , or could it be both as to the running problems it has ??
#8 Posted : Tuesday, 6 November 2007 7:21:37 AM(UTC)
if you need a new AFM let me know i have one here.
email is j_ackland(at)aapt(dot)net(dot)au
jason
#9 Posted : Tuesday, 6 November 2007 10:15:34 AM(UTC)
bundybluedog
Thanks for the replys, is an air flow meter the same as an air mass meter?
#10 Posted : Tuesday, 6 November 2007 10:15:34 AM(UTC)
bundybluedog
Thanks for the reply's, is an air flow meter the same as an air mass meter?
musksell Offline
#11 Posted : Tuesday, 6 November 2007 9:41:40 PM(UTC)
musksell
Originally posted by Dr Terry
Hi bundeybluedog.
HQ SAND MAN Offline
#12 Posted : Wednesday, 7 November 2007 4:56:59 AM(UTC)
HQ SAND MAN
Ignition module and bearing guys and C A S
#13 Posted : Wednesday, 7 November 2007 7:17:00 AM(UTC)
bundybluedog
is that the bearings in the dizzy as i replaced my whole dizzy, and whats C A S
