boom Offline
#1 Posted : Tuesday, 6 November 2007 4:48:46 AM(UTC)
boom
What's the best system i can have using mainly original parts?
from searching, i have gathered that the efi manifold with the injector holes blocked off and a mixer in place of the throttlebody would be ideal, but what mixer/gas carb would suit that.
ATM im looking into a Petrol carb converted to gas. Maybe a Quadrajet, or because the carb essentially becomes a throttlebody, maybe i should go with twin varijets or triple webbers for throttle response.
Ideas, Ideas............
If it doesn’t burn fossil fuels, it’s not a sport.
vintageholden Offline
#2 Posted : Tuesday, 6 November 2007 5:15:27 AM(UTC)
vintageholden
you can use the trottle body with a gas ring
or gas research throttle body
http://www.gasresearch.com.au/
i think you nead a converter for each carby...so stay single carby
http://www.gasresearch.com.au/convertor.html
boom Offline
#3 Posted : Tuesday, 6 November 2007 5:27:02 AM(UTC)
boom
what's the deal with the throttle body and the gas ring?
boom Offline
#4 Posted : Tuesday, 6 November 2007 5:27:02 AM(UTC)
boom
whats the deal with the throttle body and the gas ring?
Handgunner Offline
#5 Posted : Tuesday, 6 November 2007 6:03:52 AM(UTC)
Handgunner
Hi there Boom..... i have a Blocked of Fuel Injection manifold with standard VK throtle body and gas ring on my 202 in a HT Prem.... at the moment i am having difficulties getting it to start up... i am yet to wire my electronic dizzy up to 12 volts ( as
Bang Bang
boom Offline
#6 Posted : Tuesday, 6 November 2007 9:54:28 PM(UTC)
boom
do you have any pics of your setup?
#7 Posted : Wednesday, 7 November 2007 1:22:59 AM(UTC)
vintageholden
i was told if i wont fire up when cold then the converter is to far away from the throttle body...........anyone conferm this
(whats the deal with the throttle body and the gas ring?)
you cant hook gas up to any carby...need an adapter like gas ring
Edited by user Wednesday, 7 November 2007 1:24:42 AM(UTC)  | Reason: Not specified
#8 Posted : Wednesday, 7 November 2007 1:22:59 AM(UTC)
vintageholden
(what's the deal with the throttle body and the gas ring?)
#9 Posted : Wednesday, 7 November 2007 1:37:41 AM(UTC)
Cool, ididnt think of that, i think you may be right, cos the thing always took 3 goes to start , no matter what with the stromberg spudded 186.... now with the long runners , its about 3.5 foot from converter to cylinder .... makes sense..... i hope i ca
boom Offline
#10 Posted : Wednesday, 7 November 2007 2:20:35 AM(UTC)
boom
boom Offline
#11 Posted : Thursday, 8 November 2007 12:24:50 AM(UTC)
boom
what setup are you running keith??
Handgunner Offline
#12 Posted : Thursday, 8 November 2007 8:07:24 AM(UTC)
Handgunner
Bang Bang
Handgunner Offline
#13 Posted : Thursday, 8 November 2007 8:14:12 AM(UTC)
Handgunner
Hey Boom..... here is my ratty engine bay...hehe.. its a VK Manifold with little welch plugs hammered in...and with some formagasket sealer just in case... standard VK throttlebody, ( you can use larger VN one i think with slight bolt mod ) has 12 port he
Bang Bang
#14 Posted : Thursday, 8 November 2007 5:21:34 PM(UTC)
vintageholden
http://forums.performanc...1&posted=1#post839948731
check this website out thats where i got my help from
i,m going turbo soon
same setup as handunner but with impco 225 carby
#15 Posted : Thursday, 8 November 2007 6:29:06 PM(UTC)
HEY VINTAGE , HOW GOOD ARE THE 225 iMPCO GAS METERS?
I am thinking that it might be a good option..... and do i have to run a new Impco converter to use this option ,as the fella at the gas shop recommended, or would my Landi converter be ok ?
Thanks f
#16 Posted : Thursday, 8 November 2007 6:42:19 PM(UTC)
vintageholden
havent had the impco long so i,m new to lpg
go to the performance forum i posted, and send a post to JMAC
i was told to use impco 225 with impco model E converter......
