kanks Offline
#1 Posted : Thursday, 15 November 2007 5:37:46 PM(UTC)
kanks
hi can anyone tell me how to set up a kick down cable from t700 to a holley as ive been told it must be right as it will stuff the box thanks
mmazz30 Offline
#2 Posted : Friday, 16 November 2007 7:47:09 AM(UTC)
mmazz30
Kanks i have found that you need a linkage that is 28mm from the centre line of the throttle shaft to the pivot point where the cable clips in.
The arc ratio to the amount of cable pull is very important as you will fry the tranny.
Do a search on google
This page was generated in 0.017 seconds.
