BlaDe Offline
#1 Posted : Monday, 19 November 2007 8:26:16 AM(UTC)
BlaDe
Hi guys i want to put a kickdown switch on my th400 i have a wreck out the back that has a switch for the tri-matic on the accelerator pedal, will the tri switch work on the th400 and if so how on earth do i wire it up? If anyone has wiring diagrams for it that would be sweet
Thanks Blade
BlaDe Offline
#2 Posted : Tuesday, 20 November 2007 10:05:28 AM(UTC)
BlaDe
Byron, DR Terry, anyone?
#3 Posted : Tuesday, 20 November 2007 4:06:51 PM(UTC)
Yes. Same switch. There should be a plug in your wiring harness to plug into the switch. And follow the kickdown wire on the trimatic, from the firewall to the box. It is a single wire. From memory on a TH400 it follows the speedo cable down to the box.
BlaDe Offline
#4 Posted : Tuesday, 20 November 2007 10:20:17 PM(UTC)
BlaDe
sweet thank you heaps for that.
Blade
crowe Offline
#5 Posted : Wednesday, 21 November 2007 4:20:13 AM(UTC)
crowe
I did a mod on my WB Stato, I put a small push button switch below and in front of the T-Bar and in parrell with the kick down switch, so i could hold onto a gear with out moving the T-Bar. Worked well but because it only had a Trimatic in it I didnt want
This page was generated in 0.022 seconds.
