Does a 350EFI fit under the hood of the HZ without cutting the bonnet to pieces. The engine I am looking at has a Chev 350 Ramjet EFI and the supplier in WA has not fitted one under the bonnet of a standard HZ.
I think it does, but not 100% sure. To be honest, an injected Holden V8 will be cheaper and easier to fit and it definitely fits. A 350 version of these are not that hard to find, or you could simply buy a genuine or aftermarket crank and stroke it to 350 |
