6pak Offline
#1 Posted : Saturday, 24 November 2007 4:17:47 AM(UTC)
6pak
Hi Folks
I've just sent my power ram and control valve off to be rebuilt but have bit of a problem. An over enthusiastic mate helped me to remove them and while I wandered off to answer the phone, he removed the short fluid lines that go between the two without taking note of which one plugs into which hole! Would someone mind having a look at their power steering for me and tell me if the lines run top hole on the control valve to top hole on the ram or cross from top hole on the valve to bottom hole on the ram (or reverse)? A photo would be magic if thats possible.
#2 Posted : Thursday, 29 November 2007 8:25:44 AM(UTC)
Have just looked at mine and they go top hole of control valve to bottom hole ram and bottom of valve to top of ram.
#3 Posted : Thursday, 29 November 2007 8:27:59 AM(UTC)
How do you put a pic on.
Paul351xb Offline
#4 Posted : Thursday, 29 November 2007 9:04:56 AM(UTC)
Paul351xb
you need something like photobucket. Join photobucket, upload your pics to the site and then cut and paste the image here using the "img" link under the photo.
mavman4200p Offline
#5 Posted : Friday, 30 November 2007 6:39:41 AM(UTC)
mavman4200p
http://s235.photobucket....200p/?mediafilter=images
Edited by user Friday, 30 November 2007 6:40:29 AM(UTC)  | Reason: Not specified
Never take
life seriously. Nobody gets out alive anyway.
6pak Offline
#6 Posted : Monday, 3 December 2007 9:20:29 AM(UTC)
6pak
Thanks guys. You're timing is spot on as I've only just got the parts back from being re-conditioned and am now in the middle of fitting it all back on. Cheers :)
This page was generated in 0.099 seconds.
