#1 Posted : Saturday, 24 November 2007 5:23:26 AM(UTC)
Hi, Does anyone know if an older HK style double diaphram booster will bolt up to an HQ firewall? I'm after a bit more clearance and i notice the older 1's have a smaller dia but are about same length. Also the white HQ in latest Street Machine has 1 fitted but doesnt mention any dramas whith it. I'm under the impression both master cyl are 15/16". Any info would be great as iv recieved no help from local "Brake Experts"
#2 Posted : Saturday, 24 November 2007 5:56:01 AM(UTC)
They'll fit but you'd probably have to rebuild it using a HQ pushrod at the rear. Also look at V8 LH/LX or also WB disc brake (using drum brake master cylinder). The WB one will bolt in using a WB brake pedal, but you'd also have to use WB brake lines.
#3 Posted : Saturday, 24 November 2007 5:56:01 AM(UTC)
Theyll fit but youd probably have to rebuild it using a HQ pushrod at the rear. Also look at V8 LH/LX or also WB disc brake (using drum brake master cylinder). The WB one will bolt in using a WB brake pedal, but youd also have to use WB brake lines.
__
#4 Posted : Saturday, 24 November 2007 9:43:06 AM(UTC)
Originally posted by AHQUTE
Im under the impression both master cyl are 15/16". Any info would be great as iv recieved
#5 Posted : Saturday, 24 November 2007 9:43:06 AM(UTC)
ozjason Offline
#6 Posted : Saturday, 24 November 2007 7:11:46 PM(UTC)
ozjason
What's the general consensus on brake boosters? My HQ belmont ute doesn't have one. I still have heaps of braking, and it's only running a stock 202 and 3 speed, so I don't flog it along.
I've considered putting one on (are they a bolt-on item if you
ozjason Offline
#7 Posted : Saturday, 24 November 2007 7:11:46 PM(UTC)
ozjason
Whats the general consensus on brake boosters? My HQ belmont ute doesnt have one. I still have heaps of braking, and its only running a stock 202 and 3 speed, so I dont flog it along.
Ive considered putting one on (are they a bolt-on item if you sort
#8 Posted : Saturday, 24 November 2007 9:00:33 PM(UTC)
WOW! what a wealth of knowledge you have! Thanks for the help guys. I will look into your solutions. Ill be sure to use this forum next time i need advice. :)
#9 Posted : Saturday, 24 November 2007 9:00:33 PM(UTC)
WOW! what a wealth of knowledge you have! Thanks for the help guys. I will look into your solutions. I'll be sure to use this forum next time i need advice. :)
#10 Posted : Sunday, 25 November 2007 12:19:07 AM(UTC)
#11 Posted : Sunday, 25 November 2007 12:19:07 AM(UTC)
