#1 Posted : Tuesday, 27 November 2007 12:54:11 PM(UTC)
G'day guys, Ive been reading so much information on this forum its mind blowing to hear the amount of knowledge some of you out there have. So ive got afew questions about hk gts monaro's that if anyone could help me out with that would be much appreciated.
1/Can somebody tell me where the build dates are stamped on a hk gts monaro?
2/Should the big or small ID tag serial numbers be the same as the firewall numbers?
3/Was it possible to get HT interior fitted to a late buid HK?
#2 Posted : Tuesday, 27 November 2007 4:08:27 PM(UTC)
See my reply on your other post.
#3 Posted : Tuesday, 27 November 2007 5:21:57 PM(UTC)
For question 2.
The numbers are different.
The chassis number is a sequence of HKs from that plant
VIN is a sequence of cars and trucks from that plant
Engine number is a sequence number of V*s from that plant or ALL 6 cylinders at every plant.
B
