Pittin Offline
#1 Posted : Sunday, 2 December 2007 12:36:34 AM(UTC)
Pittin
Hey ive got a HX Kingy Ute and ive got no keys for it (lost them cause it was sitting for months) and i cant start it or nothing so i need a new ignition key barrel just wondering how to get too it, ive taken the steering wheel off and all that but i couldnt get any further cause there was nothing to put a puller on or to undo :S
Please Help Me
P.s. IS there any way of making it able to be started with out a key so i dont have to buy a barrel (got no money)
Pittin Offline
#2 Posted : Sunday, 2 December 2007 4:05:08 AM(UTC)
Pittin
Cmon please someone must know how to? im getting a fuel pump tomorrow so if i dont figure it out i cant get it running :(
Pittin Offline
#3 Posted : Sunday, 2 December 2007 4:05:08 AM(UTC)
Pittin
Cmon please someone must know how to? im getting a fuel pump tomorrow so if i don't figure it out i cant get it running :(
hz dude Offline
#4 Posted : Sunday, 2 December 2007 4:36:03 AM(UTC)
hz dude
you need to borrow a key because the ignition needs to be in the on postion
then you need to poke at the raised bit of the coffee pot where the ignition
sits in to break away a small retangle where a screw driver can go to push
the little catch that
Pittin Offline
#5 Posted : Sunday, 2 December 2007 5:17:04 AM(UTC)
Pittin
will any key fit it? like form a hq/z etc?
hz dude Offline
#6 Posted : Sunday, 2 December 2007 7:42:18 AM(UTC)
hz dude
most of the time and even early commodore VB -VL will fit
if the barrel is worn just give it a try
it's beer o'clock
hz dude Offline
#7 Posted : Sunday, 2 December 2007 7:42:18 AM(UTC)
hz dude
its beer oclock
#8 Posted : Sunday, 2 December 2007 8:13:40 AM(UTC)
Ill ask the wreckers when i go to get my fuel pimp tommorw if theyve got ne spares :)
clubby677 Offline
#9 Posted : Sunday, 2 December 2007 6:48:32 PM(UTC)
clubby677
Most times an old worn holden key ( HQ> even upto VK ) will do the job, but if funds are short hot wire it and put in a couple of switches one toggle for the ignition ON and a push button for the Start but this is not very secure and still no key for t
He who dies with the most toys wins!
ozjason Offline
#10 Posted : Sunday, 2 December 2007 11:13:35 PM(UTC)
ozjason
Hi Pittin,
All the ignition barrel does is pull on a rod that goes down the steering column. If you take enough of the stuff out from behind the steering wheel inside the column, you could probably disconnect the little rack and rod from the ignition
#11 Posted : Monday, 3 December 2007 9:00:57 PM(UTC)
There is a little flat piece of steel that has to be pushed with a screw driver..
You dont have to remove the rod that go to the ignition Switch on the column.
Borrow your mates key and get it cut.
Pittin Offline
#12 Posted : Tuesday, 4 December 2007 7:48:22 AM(UTC)
Pittin
When i took the indicator and all that **** off i could see like a rod with teeth on it and a bit of steel on the top of that with like a lip on it, is that what you are talking about?
#13 Posted : Tuesday, 4 December 2007 10:21:00 AM(UTC)
Yeah push it down with a screwdriver I think that'll work.
Or do you pull it . . . . I cant remember.
Looks a bit like this?
http://cgi.ebay.com.au/I...goryZ36613QQtcZphotoQQcm
#14 Posted : Tuesday, 4 December 2007 10:21:00 AM(UTC)
Yeah push it down with a screwdriver I think thatll work.
http://cgi.ebay.com.au/I...oryZ36613QQtcZphotoQQcmd
This page was generated in 0.136 seconds.
