rodudo Offline
#1 Posted : Monday, 3 December 2007 6:41:49 AM(UTC)
rodudo
i know many of u think of a rodeo as an inferior car to your HQ HZ holdens etc but i would appreciate some ideas.
4ZE1 engine idles erratic and from about 100 kph up there is no power. tested fuel pressure etc all fine ECU says ignition system. have new leads, plugs, rotor. could it be the coil? or the pickup unit in the distributor?
BTW goes well when cold but when warmas up all hell breaks loose.
Pittin Offline
#2 Posted : Monday, 3 December 2007 7:01:32 AM(UTC)
Pittin
Sell it and buy a HZ :)
Easy fix
peter_flane Offline
#3 Posted : Monday, 3 December 2007 10:00:23 AM(UTC)
peter_flane
Huh? I would be taking it to a good fuel/ignition specialist. Where to find?
I did hear of a similar thing once on a Datsun 1200, and it turned out to be a piece of plastic stuff in the petrol tank going over the fuel pickup, and it only did it on the
#4 Posted : Monday, 3 December 2007 11:24:46 AM(UTC)
Forum Rank:: Guest
hey there dont know whether this will help, but i used to have probs on a motor, when it warmed up, and it was the coil?, also had a prob once with petrol vaporizing when it got hot?
two avenues to explore?
if it is a later model, with computers and sen
Mickorf Offline
#5 Posted : Thursday, 6 December 2007 6:17:54 AM(UTC)
Mickorf
hey..i just got a workshop manual for my 96 rodeo, would be happy to copy and send to you if it will help
HQ SAND MAN Offline
#6 Posted : Thursday, 6 December 2007 6:24:51 AM(UTC)
HQ SAND MAN
coils or computer , have seen this befor . those thing do computers like you change under ware , you wanna hope its coil packs cause the computs are as dear as poison hope that helps
HQ SAND MAN Offline
#7 Posted : Thursday, 6 December 2007 6:26:01 AM(UTC)
HQ SAND MAN
ps is it a deisel cause if it is almost guarentee computer
#8 Posted : Saturday, 8 December 2007 3:05:59 AM(UTC)
OK we have an 05 RA Rodeo (petrol)here at work. A couple of years ago it ran like an old car would with the choke pulled fully. Stopped the car & re started it & the problem went away.
Took it to the Holden dealer and they said that they would need
trubluhq Offline
#9 Posted : Saturday, 8 December 2007 3:35:02 AM(UTC)
trubluhq
TAKE IT GMH and stop the stuffing around.
I have had two RODEOs and both were good. Both diesel though.
Cheers John
#10 Posted : Tuesday, 11 December 2007 4:21:35 PM(UTC)
Forum Rank:: Guest
Inferior to your HQ-HZs?????
I have an FX, FJ and an EH and they are all superior to the HQ- HZ range
#11 Posted : Tuesday, 11 December 2007 4:21:35 PM(UTC)
Forum Rank:: Guest
Inferior to your HQ-HZ's?????
trubluhq Offline
#12 Posted : Tuesday, 11 December 2007 6:36:35 PM(UTC)
trubluhq
Hi HUMPTY_P
No the message to Rod is simple. Get it to GMH. They have the gear and the guys to fix it. The Rodeo or Trooper are a good strong unit. My 97 model was a beaut and the 2001 was a dog. Isuzu, changed the gearing.
Also, any idiot can fix a
This page was generated in 0.204 seconds.
