#1 Posted : Tuesday, 21 September 2004 6:21:35 AM(UTC)
Its a VH 253 Blue and when I switch it off the motor still runs on for about 5 seconds(at the worst). I have changed the plugs and leads set the timming at 8 degrees, tried also advance timming and retarding the timming but it is still the same. It seems like its getting worse(runs on longer and getting more frequent). Does any one know whats the go on this.
#2 Posted : Tuesday, 21 September 2004 9:06:49 AM(UTC)
Your idle setting is too high.
#3 Posted : Tuesday, 21 September 2004 6:19:59 PM(UTC)
If everything is still original (rocky carb & atachments)There are 2 ajustments to make. 1 engin off ajust the screew that ajusts the butterflys so that they dont wedge shut (chokes the motor to stop) 2 ajust the idle solenoid with small spaner when e
#4 Posted : Tuesday, 14 December 2004 3:13:48 AM(UTC)
you have a faulty ignition switch try replacing the key barrel
#5 Posted : Saturday, 25 December 2004 3:54:14 AM(UTC)
mate, what your car is doing is called "dieseling" its just like when a car "pings" its fireing without any spark, try running a higher octane fuel (bp ultimate works goog in mine, a 253 vh) also try letting your car cool down abit bef
This page was generated in 0.097 seconds.
