ANYONE KNOW OF A SITE OR LINK THAT HAS COLOR CHARTS TO MATCH THE CODES OF THESE MODELS??
Try searching on the Spies Hecker site, http://www.shcolor.info/ otherwise post the codes or colour names you need info for and someone will have them. James
You only have to be in front at th |
You only have to be in front at the end of the race. |
found a site that lists all holden paint codes try htttp://www.uniquecarsandparts.com.au/colour_codes_gmh_A-L.htm or ........._gmh_M-Z.htm
Hi, Can anyone pleae help me with the below colour codes. paint 567-11905 trim 1191-10x
1191 is Monza blue metallic. 10X is black vinyl.
I thought 11905 was Verdoro
1191 is Monza Blue but the shade code would be 567-10976.
567-11905 is Verdoro Green Metallic.
James
I think there is a typo. The paint code for Verdoro is 1194.
